almost everything is in title. I have a existing routing track and via. I would like to change side of all component. It's a 4 layer, so, in a perfect world : top component goes to bottom layer
  • top track to bottom layer
  • bottom track to top layer
  • ground layer does nothing
  • and mid layer with routing is flipped.
for the the last 2 options, I'll understand if this is not automated.
Does an automatic option exist for this kind of needs ?
Thanks a lot !
Dony
  • 116
  • When you move a component from top to bottom, the footprint/pinout is mirrored, so it will not connect properly to the tracks that you moved to from top to bottom. – Peter Bennett Apr 04 '20 at 16:26
This can be done using Edit -> Move -> Flip Selection (shortcut M I). It swaps all selected objects between Top and Bottom and mirrors objects in the inner layers.
asdfex
  • 2,669
