I have two question for placement of global fiducials on my board:
- In the board below you see two fiducials and a component (SMD connector). I would like to place the connector on the very edge of the board but it would interfere with the fiducials. Is it possible to move the fiducials inwards?
- According to this document for fiducial deisgn guidelines, the placement shall be "the sum of 7.62mm and the minimum fiducial clearence" away from the board edge. In my case, the fiducial is 1mm in diameter, with a 2.7mm cutout. Does that mean I have to place it 2.7mm/2 + 7.62mm = 8.97mm away from the board edge?? Is that not a little bit too much?
