19
So this is a trivial but frustrating issue I’ve come across. I have two 5 band resistors and I am having a hard time differentiating the tolerance band.
I don’t have a multimeter on me and I don’t know if these are 1k (Brown black black brown brown) or 110ohms (Brown brown black black brown). Am I being completely oblivious to something?
Edit: I do know that the tolerance band is supposed to be at the end with the largest band spacing, but it looks equidistant to me.
Resistor
Jake
  • 331
    Just get a multimeter. Cheap resistors will be hard to read sometimes and this is a perfect example. Trying to work on electronics without a multimeter is a bit like trying to fly a plane in the dark without instruments. You're not going to get very far. A multimeter is your most basic, most important tool - full stop. You get an answer here in two seconds rather than spending half a day building some elaborate makeshift test rig to do the same job poorly. – J... Apr 01 '20 at 16:19
  • For what it is worth, you can get a serviceable (if a little slow) digital multimeter for less than 20 USD on Amazon or similar site right now. You should consider buying one. – user1850479 Apr 01 '20 at 20:24
    Oh yeah for sure. I do most of my work in a lab but given the situation labs are closed and I didn’t want to add extra burden on shipping stuff when people are trying to get essentials in. Will place an order soon. Thanks – Jake Apr 01 '20 at 21:56
    Reminds me of the time I had an inspector reject a batch of boards because the SMT 0603 resistors that should have been 560R were 195R. I took them back to him and turned the board around. – SiHa Apr 02 '20 at 08:56
    Have a spare LED? 1 k vs 110 R difference will be visible. – skvery Apr 03 '20 at 06:22
8 Answers8
33
Use 9 V block and check if the resistor becomes hot.
P = U2/R. So your 110 ohms resistor should burn close to 1 watt. (Voltage of new battery will be > 9 V.)
Transistor
  • 168,990
  • 186
  • 385
Findus
  • 668
    1k! Thanks. Compared with a known 150. The150 got much warmer than this. If it was 110 I’m sure it would have been similar or warmer. – Jake Apr 01 '20 at 09:55
    I'm sorry, but I don't agree with this answer, as is, since it's not broadly applicable and potentially harmful. What if the possible values are >10k? What if a future child reader tries this with a resistor that is some resistance that gets the resistor hot enough to burn them? – Charlie Apr 02 '20 at 07:51
    @Charlie You had me until you mentioned children. Electronics should only be handled by responsible people. Either the kid is smart enough to be responsible and not do this, or not touch electronic projects at all. – Mast Apr 02 '20 at 08:24
    Children will find other ways to burn themselves. I once discovered that mechanical pencil lead is conductive by putting it across a 9v battery. – Phil Apr 02 '20 at 16:19
    A hot resistor is probably one of the safest ways to learn about not burning yourself on hot objects. – jpa Apr 02 '20 at 17:01
    This is a terrible suggestion. Even if it does properly distinguish, e.g., 10 ohms from 1k ohms, the resistor itself is no longer useable after overheating like this. – Carl Witthoft Apr 02 '20 at 19:01
  • >Either the kid is smart enough to be responsible and not do this, [...] Right, kids should automatically be knowledgeable enough with electronic safety to not do what 24+ adults just got done telling them is OK to do ... you make a good argument. /s – Charlie Apr 03 '20 at 01:57
    Also, what @Carl said. Pushing a resistor past its wattage rating, even for only a limited time, makes it unreliable at best, totally inaccurate or out rite broken at worst. This is just all around a really bad answer. – Charlie Apr 03 '20 at 02:02
    This answer demonstrates ingenuity and an excellent intuition (which could only come from some experience). Be quick, and a 1W dissipation in a resistor won't hurt you. This is also not a semiconductor, just ohmic loss. I doubt it will take much damage. – sigvaldm Apr 03 '20 at 13:18
  • All these people who complain about the answer not being broad enough forget that answers are not supposed to be broad. – tuskiomi Apr 05 '20 at 15:12
25
Make a bridge. Feed it with low level audio signal and use a speaker as the detector. Headphones would be better than a speaker due higher sensitivity.
If R1/R2 = X/R4 the sound vanishes. Then X = R4 * (R1/R2)
In Wheatstone's bridge R1 and R2 are a potentiometer, R1/R2 is seen visually from the relative position of the slider. Originally DC voltage and sensitive galvanometer were used instead of audio and speaker.
23
These are 1k resistors, both black stripes are closer together than the two brown stripes on the bottom. The end with thicker and further apart stripes is the end with the multiplier stripe and the tolerance stripe. This is the rule with 5-band resistors, but due to how hard it is to tell them apart it is best to mark every resistor set with its value and measure using a multimeter. If you are calculating from the band colors, remember that resistor values most likely follow a value series, like E6 or E12. 110 is not part of the E6, E12 or even E24 series, but 1k is.
wallyk
  • 173
thegamebusterpl
  • 435
    This wins on "110 is not a standard size". – Harper - Reinstate Monica Apr 01 '20 at 19:11
    This is just a great answer as an electronics amateur- I can now look through all my disorganised resistors and put them back in their home, thanks!. Although honestly the bridge answer is a great one too, and recommend it against the 'does the resistor get hot' solution. – mseddon Apr 02 '20 at 15:06
You can build a circuit like
Where RQ and C1 build an RC circuit. Take a watch and measure how long it takes for the LED to turn on. Compare with other known resistors.
Thomas Weller
  • 1,008
  • A 4.7 mF electrolytic capacitor usually has large tolerances. – Uwe Apr 03 '20 at 17:34
  • @Uwe: for a 100 Ohm resistor as in question, we need a large capacitor. Otherwise, time will be quite short and possibly not measurable with a wall clock – Thomas Weller Apr 03 '20 at 20:20
5 band resistors have an extra (digit) band (3th) before the multiplier band (4th). Although a bit hard to spot (I never tried it myself), as described in this question you can start reading from the thicker band's side. So in your case it should be
$$110\ \Omega \ 1\%$$
awjlogan
  • 7,879
  • 45
vtolentino
  • 3,529
Start reading from the end of the resistor where the color bands are closer together. In the picture, that appears to be brown-black-black-brown, brown. Or 1-0-0-1, 1. Which is 100 * 10^1, 1%. 1000 Ohms, 1%.
When in doubt, get a meter. For casual measurements, I have a digital meter I bought for under $10 at a hardware store. That’s a very handy thing to have for kit building where it is difficult to distinguish colors or determine which are the thick and thin bands on resistors.
Yes, you can build yourself a Wheatstone bridge, but do you want to spend five minutes each time you check a resistor?
Bill
1k resistor. The broader band is tolerance, the spacing has nothing to do with it. When my older eyes can't see, I use my phone camera as well to magnify. That picture you took is perfectly clear. That is the way to do it for over 40's!
Jacques
Assuming the resistors are not bad in some way and the only two values you are concerned about are 110 vs 1000, the first thing to note is that there is a lot of difference - a full order of magnitude - there. Hence it is not hard to break the tie.
Do you have a small incandescent lamp (by which I mean "electronic component-sized" lamp)? If so, by hooking it to, say, a 9 V battery in series with one or the other resistor will tell you right away, as the lamp will light much brighter when the series resistor is the 110 Ω one, as compared to the 1000 Ω one (it might not be visible at all with the latter at least in normal lighting, but should be with the former.).
This is, I'd say, a better idea than trying to get it "hot", because you don't want to risk cooking one or the other resistor. An incandescent lamp is a resistor that is designed to get hot :)
