I want to measure electrical and magnetic fields of the frequency 50Hz to 1MHz with my oscilloscope. For electrical fields I learned that any bunch of metal will work. For magnetic field derivation with respect to time I learned that a search coil will do.
So I took a 30x wounded up bell wire, skinned the endings and clamped it between the tip and the ground clip of my passive oscilloscope probe.
Now I have a search coil which obviously is also a bunch of metal. What do I measure? Electrical or magnetic fields?
Hansebenger
  • 111
    This might be of help: https://electronics.stackexchange.com/questions/70697/what-makes-a-magnetic-field-probe-insensitive-to-e-fields/284845 – DKNguyen Mar 31 '20 at 19:41
This little coil will mostly respond to changing currents in its vicinity. The magnetic field caused by the changing currents will induce a voltage between the scope tip and the ground clip.
Consider a changing voltage in its vicinity, which will create an electric field. Although the changing field will likely drive some current into your little coil, most of the current will be shunted to the ground clip. The only voltage that will appear on the scope will be due to the current creating a voltage as it flows through the inductance of the coil, which is pretty small. So, your little coil will respond to both magnetic and electric fields, but mostly to magnetic fields. You have created a current probe.
user69795
  • 1,517
