I am examining the possibilities for building a cheap ethernet device that would be powered over ethernet using PoE technology. I came across this article which shows the generic block diagrams:
Looking around, I always find the DC-DC converters used in PoE applications to be isolated. I am trying to understand whether that is always necessary. Assuming that the PoE RJ45 cable would be the only cable connected to my device, is there really any reason for me to isolate from the input voltage? This is also assuming that the data lines are already isolated, so the only potentials without isolation is the power lines.
Edit:
To clarify more: I still want the TX and RX lines to stay isolated via transformers. I just want to skip the DC-DC part isolation (just graetz bridge, bulk capacitor and a DC-DC converter without isolation.) I don't mind being not compliant with the standard here. As for the shielding, I would leave it disconnected.
JRE
  • 67,678
  • 179
Łukasz Przeniosło
  • 1,619
    "Assuming that the PoE rj45 cable would be the only cable connected to my device", "also assuming that the data lines are already isolated", there's a lot of assumptions there! – pipe Mar 28 '20 at 11:57
    PoE is a standard. The standard specifies isolated DC converters. If the converter you use isn't isolated then you haven't implemented the PoE standard. – JRE Mar 28 '20 at 12:02
    How would you get 2 kV (absolute minimum) surge isolation capability if they are not isolated? Many are 6 kV rated. – Andy aka Mar 28 '20 at 12:04
  • I added more details to my question – Łukasz Przeniosło Mar 28 '20 at 13:02
  • @ŁukaszPrzeniosło my answer really doesn't change through that, unless you **specifically** have an engineering reason to not want to use an isolated DC/DC converter. – Marcus Müller Mar 28 '20 at 13:04
    Your title is *Does PoE always have be isolated?* and the simple answer is yes. If you want to power some devices using ethernet wires from unisolated supplies then you need to change your question title because PoE does not encompass what you want to do no matter how much you change or edit your question. PoE = power supply isolation to several kV. – Andy aka Mar 28 '20 at 13:09
    I see, thank you for answers. My engineering reason is to reduce the components cost. – Łukasz Przeniosło Mar 28 '20 at 13:14
  • @ŁukaszPrzeniosło I'm confused, how so? Your possible input voltage range is pretty large; this calls for a transformer-based DC/DC converter for least cost, anyway. – Marcus Müller Mar 28 '20 at 13:31
If you want to call it PoE, you need to stick to IEEE 802.3af-2003 or IEEE 802.3at-2009.
These standards call for isolation. This answer could end here: no, you cannot build a PoE device without isolation.
You also will have a shield in your ethernet cable. On which end are you going to isolate that? Both? Not much of a sensible shield then.
Also, when doing ethernet, you need the magnetics (==transformers), anyway, so get one with center taps on the cable side – no extra effort, basically every ethernet transformer does, anyway. So, without a DC/DC converter that isolates the regulated voltage from the voltage on the line, you'd tie your device's data logic to a fluctuating, noisy voltage that's not guaranteed to be at any fixed relation to the data signals.
So, really, don't.
Marcus Müller
  • 88,280
  • 131
  • 237
  • I have added more clarification to my question – Łukasz Przeniosło Mar 28 '20 at 13:03
    Unfortunately, *Power over Ethernet* and *PoE* are not protected trademarks, so there are actually plenty of devices where the term "PoE" is simply used to mean "some form of electrical power delivered over an Ethernet cable in some way", and that are in no way compliant with .3af or .3at. So, while one would *hope* that nobody would build a device that is not compliant, the unfortunate reality is that this is done in practice. – Jörg W Mittag Mar 29 '20 at 07:59
I don't have the spec in front of me but I've done a number of PoE designs. As I recall the PoE isolation spec is to meet safety requirements and avoid ground loops. If your device takes the 48 Vdc and uses it within a fully enclosed, non-conductive enclosure, with no other cables, then the 1500 Vac power isolation (typically done with a flyback circuit) isn't needed.
As noted, the RX and TX data pairs will need their own PoE rated pulse transformer since the ethernet transceiver also expects it. Don't forget the PoE power can come in either on the TX / RX pairs or on the other two spare pairs, so to be compliant you'll need two bridges.
  • Not just ground loops, but it is entirely possible for Ethernet to be wired between two buildings that have different ground connections. – Simon Richter Mar 29 '20 at 10:21
  • Only a minor suggestion. Use 48 Vdc instead of 48 Vdc to prevent line breaks. – skvery Mar 29 '20 at 12:55
Not mentioned elsewhere it is even quite possible that two different devices are powered over longer cables in the same building and then could share grounding through some common signalling cables.
The use of small diameter wires for POE and 48V drive implies that there will be voltage drops across the cables. Such drop is proportional to the current draw of the target device and dissimilar devices would see voltage drop differences that are rather different. The only way that you can mitigate these voltage drop differences is by using isolated DC->DC converters.
Michael Karas
  • 56,889
  • 70
  • 138
  • I'm still learning. Trying to imagine what the outcome in such a situation if the converters are *not* isolated. The farther-away and higher-current PD will cause a much higher voltage drop, I suppose this means it will negatively impact the rest of the network somehow. But what would happen? the nearer and lower current PD will experience a reduction in voltage? That's not too terrible is it? – Steven Lu May 20 '22 at 04:36
