Here's a YT video by Duracell about how many batteries declared dead and sent to recycling still have some usable energy. In the beginning of the video there's a sequence where they have a row of batteries and a person quickly touches each with a pair of probes to decide whether a battery is worth anything.
The measurement procedure is not documented, but I'd guess they just measure voltage on the terminals. Batteries have likely been idle for days or weeks before the measurement.
Suppose I want to do a similar project and have a pile of batteries and a voltmeter.
What's a reasonable voltage threshold to decide usable alkaline batteries from useless ones?
sharptooth
  • 12,374
  • 26
  • 83
  • 144
  • One way to get the most life out of a AA or AAA battery is to use a boost converter to deliver a nearly constant voltage (e.g. 1.8v or even 3.3v) as the cell loses power. See [this article](http://low-powerdesign.com/article_cypress_032511.html) for more. – tcrosley Nov 13 '12 at 16:48
A fully discharged alkaline cell (nominal voltage 1.5 Volts) still retains a voltage of 0.9 to 1.0 Volts. Therefore, voltage threshold for measurement can be taken as any value above 1.0 Volts.
Battery energy delivery capacity however would be limited by other factors: Internal resistance / electrode surface deterioration. A cell that has been left unused for a long period would show poor power delivery capability due to this.
One way of evaluating these "depleted" batteries would be to measure current delivered due to a brief pulsed load, i.e. a low resistance across the terminals for a brief duration.
Such a measurement device can be built conveniently by connecting a resistor and a MOSFET in series across the terminals, feeding the MOSFET gate with a series of short pulses, and reading the voltage across the resistor each time the MOSFET is switched on.
Anindo Ghosh
  • 50,188
  • 103
  • 200
-4
Some battery types are just plain dead when only slightly below nominal voltage.
My non-expert opinion is that alks' function at declining voltages is partly a matter of the device in which they are used. Battery clocks can go a long way on a 1.4v reading alkaline. Standard bulb flashlight will get you down the stairs in an emergency but you won't be reading a book while you wait out the storm. LED flashlight will signal that the light's good but battery bad - and then blink and/or dim to uselessness.
Practically, once the V. reads below 1.5 you mays well swap out the batts. A discharged battery is far more likely to leak and spoil your device or at least leave you with a cleanup job.
Sven
