I built the following circuit (physically):
V1 is my audio signal and the circuit is a simple tone and volume control. When both the volume and the tone pot are turned all the way down (so each wiper is closest to ground), some small amount of the signal can be heard on the output. It decreases as I turn the volume pot up again.
With higher values for C1, this gets worse. With lower values, say <1 µF, this behaviour disappears, however, the cutoff frequency of the low-pass filter will be too high for my purposes.
I'm at a loss as to why this happens. One reason that surely contributes to it is that I can measure a residual resistance between the Rvol wiper and ground even when it is fully closed (around 5 Ohms). I believe this is common though. I've tried to increase the value for Rvol, thinking that the output voltage between those 5 Ohms will then be lower, but this didn't help.
Any help would be greatly appreciated.
