I don't really know what the difference is between a regular diode, a zener diode, a schottky diode or an LED. Neither do I knoe the difference beetween a DIAC, a TRIAC or even a NPN transitor.
The way I see it, the difference lies on the IV curves, how the component behaves at different voltage values, so I decided to buy a curve tracer from China like this one:
But before testing it, I wanted to make sure to understand the theoretical basis behind the IV curves of some basic components:
  • Resistor enter image description here
    Let's suppose I have an adjustable voltage dource called Vs, and some kind of black box for electronic components called BBEC. In this black box you can place an unkown electronic component, and by changing the voltage values of Vs, you can trace the IV curve of that component, and this way, see what kind of component is.
So, let's place a resistor, the IV curve must be a straight line. There is an equation to model this and it is called "Ohm's Law":
$$ V=RI $$
In its differential form, it can be written as:
$$ dV=R dI $$
It is a linear relationship, if the resistance is higher, the slope of the IV curve decreases and if the resistance is smaller, the slope increases
The gray zone marks off the limit of the operating zone. If you cross the gray zone, you are going to have a burnt resistor.
From the resistor case it is possible to obtain two special cases:
  • Open circuit enter image description here No matter how much you increase the Voltage, the current is going to be zero.
  • Short circuit enter image description here
By just increasing the voltage a little bit, the current is going to increase and go to infinite. You're also going to have a burt wire.
My problem comes with the next components:
  • Capacitor
The capacitance is described by:
$$ q= CV $$
In differential form:
$$ dq= C dV $$
and this gives:
$$ i(t) = \frac{dq}{dt}= C \frac{dV}{dt} $$
So, in words, the current is equivalent to the derivative of voltage with respect time multipled by some factor C.
How does this relate to an ellipse?
The equation of an ellipse centered at the origin with width 2a and height 2b is this one:
$$ \frac{x^2}{a^2} + \frac{y^2}{b^2} = 1 $$
I was thinking that the relationship can be seen with the parametric equation of an ellipse
$$ x = a cos t $$ $$ y = b sin t $$
But I have no clue, I don't understand why a capacitor can be modeled with that equation. What physical basis does it follows that makes it arrive to the equation of an ellipse?
Also, if you cross the gray zone, you are going to have a burnt capacitor, but I am not sure if the limits are correctly placed.
  • Inductor
An inductor is described by this equation:
$$ v(t) = L \frac{di}{dt} $$
It is very symmetric to the capacitance rquation. By just changing v(t) to i(t) and L to C, you arrive at the same equation, so why is this one also an ellipse?
The difference on ellipses is that if the capacitance incresses, b increases and a decreases. In the case of the inductor, if the inductance increases, b decreases and a increases. I guess it is due the symmetry of the equation.
You might be asking, How do I know they are ellipsis if I have never seen an IV curve by myself? Well, I don't know, but that is what curve tracer sellers say on the internet:
JRE
  • 67,678
  • 179
Dau
  • 515
You are driving the L and C with a sine or cosine wave, right?
If you are driving the inductor or capaactor with a sine or cosine, the derivative terms for the inductor and capacitor I-V equations will cause more cosines and sines to pop out.
Intuitively, there is a lag time between I and V for capacitors and inductors. For L and C, one parameter reacts immediately while the other lags. The parameters are reversed between L and C so the ellipses between the two are turned 90 degrees, because the lagging parameter of one is the leading parameter of the other.
The area in the I-V loops for L and C represent the energy stored. Similarly, the area in the B-H curve also represents the energy stored. A magnetic core that stores less energy is skinnier and has less area. A resistor stores no energy so the resistor I-V loop has no area which makes it a line.
Hypothesis: B-H curves are an ellipse that is slanted the same way the resistor I-V line is slanted, rather than vertical or horizontal ellipse the L or C (until you saturate them then they turned S-shaped which still maintains a slant). Why is it slanted?
The slant in the I-V loops might have something to do with the fact the resistor is lossy and the B-H loops is also lossy. The inductor and capacitor have no loss so the curve is perpendicular (either horizontal or vertical). The B-H loop of a magnetic core that stores little energy gets narrower and skinnier so there is less area. Although, I have seen metglas B-H loops which have very vertical edges and so don't look like they slant very much.
DKNguyen
  • 54,733
  • 67
  • 153
  • Well, I am not directly driving the L and C with a sine or cosine wave. It is the the Curve Tracer the one who is driving it, I am not sure if it is doing that – Dau Mar 18 '20 at 22:38
  • @DieDauphin I think it's a reasonable assumption. Why would it drive it with anything else? After all, sine or cosine drive means you are testing it at a particular frequency. Driving it with anything else means testing it at an ill-defined frequency. – DKNguyen Mar 18 '20 at 22:42
  • So, the IV curves of capacitors and inductors are going to depend to the voltage is driving them? .. What happens if the capacitor is discharged and I start driving it from cero .. I mean, at V=0 is not going to have the current that the graph shows – Dau Mar 18 '20 at 22:46
  • @DieDauphin Not only that, they are also dependent on the frequency at which you drive them with. Same with B-H curves. Changing the voltage or frequency makes the shapes get bigger or smaller. – DKNguyen Mar 18 '20 at 22:47
  • I guess a good laboratory practice would be to see what kind of voltage is the curve tracer using to drive the components (frequency, aplitude ... ) – Dau Mar 18 '20 at 22:49
  • @DieDauphin I've never actually done a IV trace like you have. I've only done B-H so pretty much everything I am telling you here is based on that. The first time I did the B-H I was really confused because I was expecting an S-shape, not slanted oval. It wasn't until I realized the S-shaped shows saturation that I realized I had to turn the current up. And messing around with that I realized a lot of things like frequency and voltage/current change the shape and size. It's not a line tracing out your loop as much as it's a fuzzy cloud gradient covering all possible operating conditions. – DKNguyen Mar 18 '20 at 22:52
  • The IV curves of semiconductors components (transistors, diodes, DIACS, TRIACS) are also going to change with the frequency? How do you do B-H Curves? – Dau Mar 18 '20 at 22:52
  • @DieDauphin I guess they would have to but that would be a very different kind of I-V curve. The I-V curves you see everywhere are shown for static values (similar to how the S-shape B-H loop you see everywhere is under saturation) – DKNguyen Mar 18 '20 at 22:53
  • @DieDauphin H is proportional to current and B is proportional to the integral of the voltage. So you XY plot the current against the voltage integral. If you have a fancy scope that can integrate and XY plot you don't need external circuitry other than the coil and the AC supply. If you don't then you need voltage integration circuitry. – DKNguyen Mar 18 '20 at 22:54
For an inductor, \$L\$, if the current is \$i=Isin(\omega t)\$ then the voltage will be \$v=\omega LIcos (\omega t)\$, which is the locus of a circle on the \$iv\$ plane if \$\omega L=1\$, and an ellipse if it's not.
Chu
  • 7,485
