I'm designing a 4 layer mixed signal PCB with sensitive analog circuits and RF-digital circuits. The board have many mechanical constraints so the places of the analog and digital circuits are fixed.
When designing the ground plane I added some ground cuts. The idea was to make the digital return currents flow seperately under the analog return currents without disturbing the analog currents: enter image description here
Is this a good grounding?
Is this a good idea / necessary to seperate the ground using this ground cuts? In the return path of analog currents, there are no sensitive components. But without the ground cuts, the digital and analog return currents would somehow "collide". Thus, the analog ground would be noisy. Are my considerations correct?
How to achieve the star topology?
The seperation of digital and analog grounds with a bridge under the DAC is the recommended way. But then I would have star point right under the ADC. However, my DC-Jack is far away from this point on the top left edge. And the path from the ADC to DC jack is going over the digital SMPS. And the ground of this SMPS is not connected to the ADC but it would return directly to the DC-Jack above.
I could connect the digital SMPS ground directly to the star point under the ADC, and then connect this star point to the DC-Jack=>But this looks very strange to my eyes. I didn't see designs like this.
What do you think, what would be the best grounding for this board?
Caniko
  • 295
  • Cuts in the ground plane may not be the right approach. Return currents for high speed digital signals want to flow as close to the signal trace as possible in order to minimize the loop inductance. If you have digital signal traces that cross those cuts on another plane, you're going to force the return currents to take a detour, increasing the loop area and so increasing emissions. – SteveSh Mar 16 '20 at 21:16
  • If your analog stuff is really "sensitive" as you claim, why are you using a SMPS for the +5V for the analog? – SteveSh Mar 16 '20 at 21:19
  • No high speed signal is crossing to the left half. The RF part is on the bottom right part. Thus may be the ground cuts are overkill, since they're seperating the ground between ADC and DSP. Well, sensitive was not the correct wording. That's an audio board. There shouldn't be any perceptible distortions. I already designed another board supplying analog section with an SMPS, which doesn't have any audible disadvantage to the LDO regulators. – Caniko Mar 17 '20 at 17:28
  • Are the Analog circuits completely independent from the Digital circuits? Are all Analog signals going over the ground bridge? Do you have ground planes on any other layers? – eeintech Mar 23 '20 at 12:39
  • Analog circuits are completely independent from digital circuits, no analog signals going over ground bridge (only analog PSU return). No another ground planes. – Caniko Mar 23 '20 at 13:38
Let's get one thing absolutely clear: split/partitioned ground planes are never necessary, but they can be a useful technique to mitigate human error. But you can always achieve equal or slightly better performance using a single, unpartitioned or slotted ground plane and careful routing of your board.
However, most mixed signal routing is also fairly unforgiving - a single mistake in the form of a poorly placed trace (and not necessarily an obvious misplacement, like a trace that crosses a ground split) is all it takes to completely ruin the analog performance of a board.
So in reality, split ground planes are more of an insurance policy than anything else. They can prevent some of the more subtle mistakes that a designer might make in their layout have a minimal impact on the board. The down side to having split or partitioned ground planes, however, is that your board is now a nice little dipole antenna (and if you have more than 2 planes, the board is multiple dipole antennas), which is something that should be considered. Obviously, a good many mixed signal boards in existence do in fact use split ground topologies, so in many, if not most cases, the noise picked up due to this parasitic dipole is not enough to really even be a design consideration. But it will cause the board to couple more exogenous radiated garbage into your noise floor, and your board will also likewise radiate more than it would with a single unbroken ground plane.
Alright, let's start the deep dive on this.
  1. Remember why circuits are named circuits.
    With electric currents, everything is a loop. It is always circular. A circuit. Our design methodologies and abstracted frameworks and simplifications of the physical processes that actually occur very much tend towards the idea that ground is a pristine 0V potential source that all things are forever and always referenced to, and no current ever really flows through ground, it is simply where our power and signal currents all happily and quietly return to.
    Of course, we know better. We know that every different spot of a ground plane, every different connection to ground, as soon as any current is allowed to flow, that current also flows through ground. And that current causes a voltage drop, and all those spots are no longer really at that single, glorious 0V ideal we pretend is there. Everything is at slightly different potentials, and always changing as our return currents change. Which parts of ground experience how much change in potential and due to what is entirely dependent on the path of those currents.
    You've certainly begun thinking about return currents, which is great. And therein lies the trick to all this: if you understand how ground return currents behave, then you can control that behavior, and thus control what will effect what on your board, entirely by how you route that board.
  2. The ground currents are not a some cabalistic fog of uncertainty.
    In fact, the currents you need to worry about are some of the most well-behaved. Let's be clear, too, what currents we are worried about. Unless something is terribly wrong, generally we are worried about digital signal return currents causing problems for our sensitive analog section. The analog section isn't just worried about discriminating between 2 extremely wide voltage or current levels as with digital, but instead is trying to measure something. Usually that something ultimately is in the form of voltage, which means our measurement is really only as good as the ground we're measuring it in reference to.
    Digital signals can seem fearsome to someone looking at them from an analog design stand point. These signals are not sinusoidal at all, they are not gentle or smooth. They're sharp, with fast rise times often in the nanoseconds if not faster. You have coherent noise from clocks, and every little transition from high to low, from a 1 to a zero, is a sharp swing that slams the current like a hammer, making it ring, causing broad spectrum noise whose power vs frequency distribution is determined by the rise time of that digital waveform. Honestly, it would not be bold to call all of that an analog designer's worst, or nearly worst, nightmare.
    But there is also a tremendous advantage bestowed upon us by the aforementioned nature of digital signals. They're fast. They don't behave like DC. They're too fast to diffuse very far from the current that we are thinking about, the signal current, the current that flows through a well-defined trace.
    Here is a graph of the current distribution (generally) for digital signals. (Credit: Henry Ott - Source PDF) enter image description here
    The bottom axis is a ratio of distances. \$ h \$ is the distance, vertically (as in, your PCB stackup heights) between the signal trace and its ground plane. \$ x \$ is the distance from the center of the signal trace outward. For this reason it is preferable to have a ground plane immediately adjacent to your top signal plane if possible. But even being conservative and assuming substantial gap, say, 1mm, that means that over 87% of all the return current for a digital signal is within 5mm to either side of the center of the signal trace. Under it, of course. If you have a modern multilayer board, there may be on the order of 100µm of prepreg between the top traces and an inner ground plane. This will localize the return currents further, as all that matters is the ratio. 97% of the ground return current will be within 20 times the gap between the signal trace and its ground return plane. For a proper stackup with 100µm of gap, that's a 4mm band that directly follows the path of that trace.
It's important to understand the numbers, but the important takeaway here is that your ground return currents follow the traces that causes them. Yes, they spread out a little bit, but you can control to what degree, and if you know how much they spread, well, that's all the information you need. Route your traces and keep them with enough of a safe distance from anything on your board you don't want that return current to flow under (thus impacting the ground there locally), and you can achieve exactly the same thing as you can with split grounds. All the split ground does is it ensures that the limited degree current for those fast signals even CAN spread out, if the designer makes a mistake and places a trace too close to the wrong thing, a split will place a hard galvanic barrier preventing that return current from reaching whatever sensitive trace or what have you is nearby.
But you can also have a single ground plane with well-routed and spaced traces where they're needed and accomplish the same thing.
In most cases, I would argue that the benefits of using a split plane probably outweigh the minor disadvantages, since we all make mistakes, and like I said, mixed signal applications are not very forgiving. But you never actually need to split up your grounds.
metacollin
  • 27,884
  • 64
  • 119
  • I agree with all of this, but some interesting advice I saw was to design everything with the split ground, and then as the last step, connect all of the grounds together as one copper pour. This gives you the majority of the benefits of split grounds, without actually having a split grounf – BeB00 Mar 21 '20 at 07:55
  • Useful infos. I also understand your points. But my uncertainity is based on the big picture of this circuit. Theoretically, the current will flow from the dc jack plus pole to any loads on the board and then return back to the minus pole through the shortest path (more precisely: always following the lower potential). Thus, the supply current (ideally supplying bypass caps of digital circuits) would flow back over the analog ground to the top left corner. Thus I would need a ground cut! – Caniko Mar 21 '20 at 11:14
  • While informative, I don't see how this is relevant. The proposition here is NOT a split ground, but a slotted one... – grambo Mar 22 '20 at 21:27
    @Caniko You need to keep a few things in mind. The current path is not as you describe. There is a low frequency current path between the power jack and the power supply. At this point you have a low frequency (DC more or less) component and a high frequency component. Now the low frequency component travels in the ground plane, but it covers a large area. So the voltage drop in the ground plane tends to spread out. This cancels out the effect, since the ground plane changes everywhere. Also the voltage change is lower from the low frequencies due to skin depth, power density etc. – user110971 Mar 24 '20 at 10:51
    @Caniko The high frequency current does not follow the shortest path. It follows the path of least impedance. For currents in the 100 kHz range and above this is the path that minimizes the loop area. So the return current follows the trace and does not take a straight line, as this answer demonstrates. – user110971 Mar 24 '20 at 10:57
  • Nice answer. One small correction (though, this is irrelevant for the question):"every little transition from high to low, from a 1 to a zero, is a sharp swing that slams the current like a hammer, making it ring, causing broad spectrum noise whose power vs frequency distribution is determined by the rise time" Actually the ringing is caused by impedance mismatch, not the fast rise time. Also, the frequency of the ringing is determined mostly by the length of the trace. – TemeV Mar 26 '20 at 19:19
Something I learned years ago (decades?) from a couple of great FAE's from Unitrode: "the chainsaw rule". Basically you have the major ground cuts correct, but you must follow the rule that you need to be able to cut the fiberglass with a chainsaw right thru the ground cuts that you have made. I.e., don't put any traces or copper pours over those cuts. Power or signal, everything must go over ground copper. You will likely need to widen the ADC ground area to support the signals/power that also needs to bridge two zones, but in the end you have your star at the ADC which is where it needs to be. The lower cut from the ADC down and left I will contest, as I think you will be forced to eliminate that cut to accommodate the digital connection to the ADC (to adhere to the chainsaw rule). ...side note, perhaps it should really be a "scroll saw rule"
grambo
  • 121
