I'm currently using circuits.io to create a very simple circuit. However, before ordering the board, I would like to print it in order to see if it's the right size and/or the elements fit in my own designed footprints.
Since circuit.io only lets you download gerber files, is there a simple way to print those gerber files? Maybe if someone can point me to the spec for the gerber files I could craft a simple script to convert the file to something that I could actually print.
funkaster
  • 81
gerbv - A Free/Open Source Gerber Viewer, part of gplEDA, does what you want. Specifically it is at http://gerbv.geda-project.org/.
Brian Carlton
  • 13,252
  • 43
  • 64
  • thanks, I'll try that... as soon as I can compile it :S the macports version is not compiling right now, and I haven't found a binary version – funkaster Nov 07 '12 at 22:13
  • ok, I completely wiped out macports and installed fink... that did the trick! thanks :) – funkaster Nov 07 '12 at 23:24
    just an update: I removed fink and I'm now with [homebrew](http://mxcl.github.com/homebrew/), that seems more updated and it worked right out of the box. – funkaster Nov 13 '12 at 20:38
With Homebrew installed, type in your terminal:
brew install gerbv
let it install then type:
gerbv
and it will open
seantomburke
  • 121
gerbv is available for OS X. It can print to PDF or PostScript.
markrages
  • 19,905
  • 59
  • 96
