I've been teaching myself electronics and a current approach I am taking, is to be able to describe the purpose of every element in the standard TTL NOT gate:
At this point I understand the purpose of each of the transistors, the diode, and how the 130 ohm resistor supports the desired fanout. I'm still trying to figure out the other resistors. So for the 4 kΩ R1, 1.6 kΩ R2, and 1 kΩ R4, I'm trying to understand why these values (versus, say, 5 kΩ, 2 kΩ, and 1.6 kΩ respectively, for example).
So I have two specific questions:
Why would you choose those specific resistor values (if you were designing this circuit)?
If the values are chosen to support specifications (e.g. a particular sink current amount on the input), why would that specification be desirable in the first place?
Any help will be appreciated. Thanks!
