I would like to add Raspberry Pi Compute Module 3+
to my design.
My design has an ethernet switch KSZ8895
on board. The 5th port can be configured for using MII
It is known that the Compute Module (CM) provides Ethernet and USB via an IC. It is mostly LAN9512 or LAN9514
. But, I am not sure whether I can directly interface LAN951x to one of the ports of KSZ8895
. I don't want to use RJ45 to RJ45 connection to the switch via a short UTP cable, it is not desired as you may understand for a custom design.
I am also open to any other alternatives to LAN951x
if it would be better for interfacing to KSZ8895
while still providing internet to CM. In this case, I can volunteerly sacrifice USB option which LAN951x
provides.
A piece of schematic from the switch circuit;
if possible, I like to interface KSZ8895
without transformer H1102NL
