community! I have a problem as follows. I've been trying to interface the LM19 temperature sensor using Arduino. I made a function to read and compute the temperature from the sensor according to a formula described in its datasheet. The result was pretty good. However, when I added another function for reading ADC value from an LDR, the result of the temperature computation went crazy!!! Here's my code:
 Author: M. Chenda
 Created on Tue Feb 18, 2020
#define ldr 0       // assign LDR's pin to analog pin A0
#define light 8     // assign LED's pin to digital pin 8
#define lm19 2      // assign LM19's pin to analog pin A2
int ldr_val = 0;    // LDR's ADC reading variable
String state;       // string representing light's state
int lm19_val = 0;   // LM19's ADC reading variable
float Vo = 0.00;    // V output of LM19
float temp = 0.00;  // temperature variable
void setup() {
    pinMode(light, OUTPUT);
    Serial.begin(9600);
    while(!Serial) {;}  // wait for serial port connection
void loop() {
    lighting();
    temp_control();
    delay(500);
/*  LIGHT CONTROL   */
void lighting() {
    ldr_val = analogRead(ldr);  // read LDR's ADC value (brightness)
    if (ldr_val < 512) {
        digitalWrite(light, LOW);
        state = "off";
    else {
        digitalWrite(light, HIGH);
        state = "on";
    Serial.print("LDR's ADC:  ");
    Serial.println(ldr_val);
/*  VALUE MAPPING FUNCTION  */
float mapping(float x, float in_min, float in_max, float out_min, float out_max) {
    return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
/*  TEMPERATURE MEASUREMENT */
void temp_control() {
    // read LM19's ADC value
    lm19_val = analogRead(lm19);
    // convert the ADC value to voltage (0 to 5V)
    Vo = mapping(lm19_val, 0, 1023, 0, 5);
    // compute temperature value in Celsius
    temp = -1481.96 + sqrt((2.1962*pow(10,6))+((1.8639-Vo)/(3.88*pow(10,-6))));
    Serial.print("      Temperature (Celsius):  ");
    Serial.println(temp);   // print the measured temperature to Serial Terminal
enter image description here What could be the root of this problem?
M. Chenda
  • Your code could be faultless but if you connect / use the LDR in the wrong way then it will not work anyway. You need to include a **schematic** to show how you have connected things. What works with an LM19 will not work with an LDR unless you add a circuit that will output a similar as the LM19 does. – Bimpelrekkie Feb 18 '20 at 07:23
  • Please share the connection diagram, also state what went wrong.. saying crazy means nothing to solve the problems.. was there offset observed? If yes how much. Was there random values sometimes and normal operation.. does commenting the control section eliminates the problem? – User323693 Feb 18 '20 at 07:55
  • @Bimpelrekkie I added a quick reference of my schematic. Please take a look. Also, I want to mention that lighting() function works correctly either lighting() and temp_control() functions are called or only lighting() itself is called. – M. Chenda Feb 18 '20 at 08:08
  • @User323693 I've just added a quick reference of my schematic. Please take a look. What went wrong is that when I added the `lighting()` function in the `loop()`, I received random values of `temp` from `temp_control()` function. And yes, when I commented out the `lighting()` function, my temperature computation function worked correctly again. – M. Chenda Feb 18 '20 at 08:16
    How long are the wires to the LM19? Is the "quick reference" schematic **exact** as-built? For example, are there any capacitors that are not shown in the schematic? Finally, what happens when you read ADC 2x for each input and discard the first measurement? – Spehro Pefhany Feb 18 '20 at 09:06
  • @SpehroPefhany I'm testing this project on a breadboard, and my cables are no longer than 15 cm. Devices are connected exactly as shown in the schematic. Anyways, reading each ADC twice actually works. Now I'm receiving a stable result of temperature measurement. Wow! Thank you! Would you explain what's going on? Please make it an answer, and I'll accept it. It might be helpful for others as well. – M. Chenda Feb 18 '20 at 10:12
The ADC has a built in capacitor at it's input. So, you should allow the capacitor to charge slowly to the actual value. If there is high resistance (LDR), it will take more time to charge.
Since, you are switching the ADC to different channels, you should give sufficient time for the ADC sampling capacitor to charge.
Provide sufficient delay after choosing the channel - OR read the ADC several times, and consider the last couple of values once the values are stable. You can read once, give a delay, and do a second read.
User323693
  • 9,151
  • 50
  • I tried adding a delay for each ADC reading, but it didn't work (plus, I can't afford to slow down the execution of my instructions). However, repeating the ADC reading for each channel actually works. Thank you! – M. Chenda Feb 18 '20 at 16:46
A minor thing but I would suggest changing
to
#define ldr A0       // assign LDR's pin to analog pin A0
#define lm19 A2      // assign LM19's pin to analog pin A2
I don't expect it will solve your issues (and I can't see any issue with your code) but it is good practice to use the channel numbers.
Further reading on the subject: analogRead(0) or analogRead(A0)
markcra
When you change channels the input section of the ADC requires a bit of time (depending on the source impedance and the difference between the previous and new voltages) for the reading to settle to the new value. Adding a delay or discarding the first reading of the new channel can mitigate that effect.
Edit: To be useful, the delay would have to be inserted after setting the multiplexer but before initiating the ADC read, so inside the analogRead function. If you look at the source code, there is a commented-out delay.
Maybe this is a FAQ in the Arduino community.
Don't forget to pay attention to the capacitance loading notes on the temperature sensor if you extend the least, they are not tolerant of capactive loading beyond a couple hundred pF and can oscillate or ring.
Spehro Pefhany
  • 376,485
  • 842
  • I tried adding a delay for each ADC reading, but it didn't work. However, repeating the ADC reading for each channel actually works. Thank you! – M. Chenda Feb 18 '20 at 16:42
