Below is a pi model schematic of a cascaded amplifier. The goal is to find the gain with Rp as load. enter image description here
So the gain would be: \$ A = \frac{V_{out}}{V_{in}}\$. So i set out to find \$V_{out}\$ in terms of \$V_{in}\$ as \$V_{out}=i_{Rp}R_p=\frac{300}{500}\beta i_{b2}R_p \$
I believe the answer is very simple, but I can't seem to express \$i_{b2}\$ in terms of \$i_{b1}\$ and thus \$V_{in}\$ because of the current \$i_1\$.
math101
  • Simply try \$ \Large i_{b1} = \frac {V_{in}}{r_{\pi 1}} \$ – G36 Feb 13 '20 at 15:46
  • Yes, but how do I express \$i_{b2}\$ in terms of \$V_{in}\$. Current \$i_1\$ is bugging me (the node marked with an asterix). – math101 Feb 13 '20 at 16:00
  • Are you need a symbolic expression for a voltage gain or just a number (voltage gain)? – G36 Feb 13 '20 at 16:05
  • I need an expression. See, \$i_{b2}=i_1-\beta i_{b1}\$ and thus \$i_{b2}=i_1-\beta \frac{V_{in}}{r_{\pi 1}}\$ but \$ i_1\$ is unknown. – math101 Feb 13 '20 at 16:10
  • In that case, you need to use any circuit analysis techniques you know and solve the circuit as we do with the DC circuit, Or we can notice that the Q2 is an emitter follower and we know Zin for a voltage follower. So the IB2 current will be equal to \$\Large I_{b2} = i_{b1}*\beta * \frac{R_1}{R_1 + r_{\pi 2} + (\beta +1)*R_E||R_P}\$ See here: https://electronics.stackexchange.com/questions/476659/kvl-equations-for-this-small-signal-model/476666#476666 – G36 Feb 13 '20 at 16:19
  • Ah, now I get it. The resistance of the right amplifier stage could be written as \$r_{\pi 2}+(\beta + 1)*R_E||R_P\$ and then I have two branches to which the current \$I_{b2}\$ branches out to. Thank you! – math101 Feb 13 '20 at 17:43
  • I'm glad I could help. – G36 Feb 13 '20 at 18:37
Well, we have the following circuit:
I used Mathematica to write a code using KCL and KVL. The code I came up with is the following:
FullSimplify[
 Solve[{Iin == I1 + I2, I3 == I2 + β1*I2,
   0 == I4 + I5 + β1*I2, Ie == I5 + β2*I5, Ie == I6 + I7,
   I1 == Ia + Iin, Ib == I3 + Ia, 0 == I4 + Ib + Ic,
   Id == Ic + β2*I5, Id == I6 + I7, I1 == (Vin)/R1,
   I2 == (Vin - V1)/R2, I3 == (V1)/R3, I4 == (V2)/R4,
   I5 == (V2 - V3)/R5, I6 == (V3)/R6, I7 == (V3)/R7}, {Iin, I1, I2,
   I3, I4, I5, I6, I7, Ia, Ib, Ic, Id, Ie, V1, V2, V3}]]
Using your values I got the following code:
FullSimplify[
   Id == Ic + β2*I5, Id == I6 + I7, I1 == (Vin)/100000,
   I2 == (Vin - V1)/1530, I3 == (V1)/R3, I4 == (V2)/2200,
   I5 == (V2 - V3)/359, I6 == (V3)/300, I7 == (V3)/200}, {Iin, I1, I2,
I left \$\text{R}_3\$ as it was because I need to set it equal to \$0\$ and than I will get an error message because then I will divide by \$0\$. Later I will take the limit.
Entering the code I got the following result:
{{Iin -> Vin (1/100000 + 1/(1530 + R3 + R3 β1)),
  I1 -> Vin/100000, I2 -> Vin/(1530 + R3 + R3 β1),
  I3 -> (Vin (1 + β1))/(1530 + R3 + R3 β1),
  I4 -> -((Vin β1 (479 + 120 β2))/(
    3 (1530 + R3 + R3 β1) (893 + 40 β2))),
  I5 -> -((2200 Vin β1)/(
  I6 -> -((880 Vin β1 (1 + β2))/(
  I7 -> -((440 Vin β1 (1 + β2))/((1530 + R3 +
  Ia -> -(Vin/(1530 + R3 + R3 β1)),
  Ib -> (Vin β1)/(1530 + R3 + R3 β1),
  Ic -> -((2200 Vin β1)/(
  Id -> -((2200 Vin β1 (1 + β2))/(
  Ie -> -((2200 Vin β1 (1 + β2))/(
  V1 -> (R3 Vin (1 + β1))/(1530 + R3 + R3 β1),
  V2 -> -((2200 Vin β1 (479 + 120 β2))/(
  V3 -> -((88000 Vin β1 (1 + β2))/((1530 + R3 +
       R3 β1) (893 + 40 β2)))}}
Now using your gain formula we will end up with:
$$\text{G}:=\frac{\text{V}_3}{\text{V}_\text{in}}=\lim_{\text{R}_3\to0}-\frac{88000\beta_1\left(1+\beta_2\right)}{\left(1530+\text{R}_3\left(1+\beta_1\right)\right)\left(893+40\beta_2\right)}=$$ $$-\frac{8800\beta_1\left(1+\beta_2\right)}{153\left(893+40\beta_2\right)}\tag1$$
Jan Eerland
  • 7,203
