I am developing a 10.7 MHz IF amplifier for a radio receiver. In order to match the input to the output of the driving mixer stage (330 ohm) I need to measure the input impedance.
I did the measurement with a NanoVNA (I don't have access to a professional VNA), that I bought via the well known Chinese website. Though I have reasons to believe the Nano is reasonably accurate, the problem that I encounter is that the output level of the VNA drives the amplifier way past it's 1 dB compression point, so it is unsure if the measurement is correct. The capabilities of the NanoVNA are very limited, and it may not be possible to reduce the power level internally.
I read a suggestion to pad the S11 output with a T or PI pad attenuator, and use the output of the pad as reference plane, so in effect do the OSL calibration behind the pad:
Is padding the output like this a common approach, and will the measurements be sufficiently accurate? I estimate the required attenuation to be 10 up to 20 dB.
Bart
  • 875
Theoretically this would work, but there are some real life limitations. For instance, with a 20 dB pad, is the expected reflected power still within range of the analyzer? Also, the return loss of the pad would have to be pretty good (~better than 30 dB) to get accurate results.
If you have known test units that you could try with and without the pad to see if the results correlate, you could gain more confidence. A test device with 0 dB would be easy to measure. A test device with 20 dB would be much more difficult.
BEE
  • 546
  • I made some quick calculations on a 20dB T-pad attenuator (series resistors 40.91 ohm, shunt resister 10.01 ohm), and I concluded that the VNA will see at most 1 ohm input impedance variation between the pad opened, shorted or loaded with 50 ohm. I doubt my VNA is sensitive enough to correctly process this, Would any VNA be sensitive enough for this? – Bart Feb 06 '20 at 10:00
A way to measure s11 at low level with the nanoVNA is to make a hybrid combiner, which is easily done at 10.7M then use this to make a s11 measurement of DUT, measured as s21 on the nano. you can then put a pad in the output port of the nano and it will not introduce errors.
If you do it as you suggested the reflected power from the DUT appears at the nano attenuated by twice the pad value, but any mismatch looking into the pad is not attenuated, it is unpredictable what this error vector will do.
SamGibson
  • 17,231
  • 58
paul
  • Let's see if I understand this right. I make a 3dB hybrid for let's say 90 degrees. I connect the padded S11 output of the nano to the hybrid's input, terminate one of it's outputs with 50 ohm, and the other one with the DUT. I can than connect S21 of the nano to the isolated output, so all reflected power from the DUT will appear at S21. Do I interpret this correct? – Bart Aug 18 '20 at 10:46
