EDIT: I've attempted to aggregate the answers (and some more of my own practical experiments) below.
For context, I want to use a single ADC input to read several independent temperatures. The temperatures will be in similar ranges, and the same thermistor type will be used for all of these. Sample rates in the order of a few times per minute will be plenty for this, so I figure that I should be able to time-multiplex the single ADC input on the ESP8266 that I plan to use for this.
So, I need a circuit that will allow me to select one of more-than-one thermistors arranged in a simple voltage divider. I've never used a MOSFET before, and my formal training in electronics both rather limited, and most of 40 years ago. Given that background, however, I did some reading, and I think I have a fighting chance at making the circuit sketched below work adequately to the purpose. However, since I don't know what I don't know, I'd like to ask if I'm doing something that's doomed to failure, or horribly inadequate in some way.
I plan to use the (dirt cheap and readily available, perhaps due to being discontinued!?) 2N7000 MOSFET, data sheet here: https://www.onsemi.com/pub/Collateral/NDS7002A-D.PDF along with thermistors that are around 100K in the region that I'm interested in measuring. From that, I figure that if I set R1 at 100K, I will have a reasonable spread up and down (I'm not interested in optimizing the use of the ADC range, just getting an indication of temperature variation allowing some crude "prevent freezing" control).
My hope is that if I set one of the enabling inputs (e1, e2) at Vcc, while the others remain at 0V the circuit will in effect "turn on" that thermistor, while very high resistance paths will effectively shut out the others from being significant in the parallel configuration. Consequently, I expect to measure a signal that's effectively derived from the potential division between R1 and the single "enabled" thermistor.
So far as I can make out from the theory I've been reading, provided the gate voltage it high enough, the eMOSFET will effectively become a very low resistance (in the region of a few ohms, in this device, I believe), provided the current remains small.
I will drive the gate with either Vcc, or 0 volts, and I believe this means that the current will be controlled primarily by the resistor and thermistor with the FET appearing as either a short, or open, circuit, at a first level of approximation. Using the magical "simulate" feature of this circuit drawing tool (how cool is that, never knew this existed till I tried to start drawing!) the software seems to think this might work, but I have some specific questions:
  1. Is this in fact workable, or did I miss the point completely on the MOSFET characteristics in a way that the simulation misses too?
  2. Is the device I selected OK for this mode of use?
  3. Does the circuit itself need anything additional to provide ongoing static protection (I am aware of the precautions I need to take while handling the devices).
  4. What didn't I ask that I should have!?
Other notes, likely not significant to my questions, but which might save someone the effort of making notes on these topics:
  1. I will probably have more than two inputs
  2. I couldn't find a symbol for thermistor, so used LDR instead--I do know the difference :)
  3. I will probably use an 3-8 decoder to drive the various enabling lines, to avoid using too many of my digital outputs.
UPDATES HERE
Several answers and comments have been submitted, and they all add something. At this point, I have prototyped the circuit I proposed and run some tests on it.
With two FETS, 5volt regulated power, and using 100K and 10K fixed value (5%) resistors in place of the thermistors, I find that the total voltage lost due to leakage current is about 0.46 volts (that is "all channels off" measures 4.54v), suggesting the leakage current of the particular randomly chosen 2N7000 devices I used is about 4.6 microAmps. I have no doubt that that's quite enough to justify Andy Aka's concerns for a professional engineering project with commensurate tolerances. It will, for sure, make number crunching based on the beta value of the thermistor inaccurate.
I figured that the 2N7000 data sheet shows the leakage increasing with increasing ambient temperature (that figure above was at "room" temp, so probably IRO 65~70F). So, I blew warm air at it with my little heat gun, and the leakage actually seemed to drop a tiny bit ("all off" voltage rose to 4.56v). At the time that I measured, an infrared pyrometer reading of the general circuit board area suggested things were approaching 130F case temperatures--of course, that's not the same as suggesting the semiconductors contained in those cases had necessarily reached those temps, but things had pretty much stopped changing at this point). So, it didn't seem like (with these particular device instances) raising temperatures would cause much variation.
In my case, I'm more than happy to calibrate the setpoints manually, so I'm not too concerned about the thermistors "1%" quoted accuracy, nor about doing calculations based on the beta value. On that basis, I think it's fair to say the circuit is a "success" from the perspective of a hobbyist building a one off circuit, for a low precision application, by hand.
It's also fair to say this would not be professional-grade engineering :)
Next I had already bought some cheap (from Amazon! Sorry Andy) CD4051BE multiplexers before Andy had a chance to answer with a suggested device. These show up tomorrow, and I'll try them out then. Given that the very crude original circuit proposal is "good enough" but that the 4051 will be much easier to use, I expect to end up going this route (but will test and report back if anything very interesting shows up). I will note that Andy's suggested device is IRO $5 for a single unit (or was at the place I found it) but the 4051 was $8 for ten (including shipping).
2nd UPDATE
I built out a test of the CD4051, and it works like a champ. Feeding inputs from two different dividers into two of the inputs, and switching them through the 4051, I couldn't see any difference on my modest quality 2 decimal place meter.
So, even though the original proposal is "workable" for this level of hobby application, the 4051 wins hands down for at least two reasons, 1) it will allow far more accuracy, and 2) it includes a 3 to 8 decoder to select the input (I likely only need three or four inputs in this project, but excess is not a problem here of course). So, while it might not be as good as Andy's proposal, it's way good enough for this, and at $8 for ten, it's a gift.
Thanks to everyone for valuable input, I enjoyed the learning, experimenting, and at least being roughly right to a first approximation in my first MOSFET "design". I'm marking Andy's answer as "the answer" since he pushed me toward the "use a device for the job" solution.
Toby Eggitt
  • 708
    2N7000/2N7002? Discontinued? No way. This little beast will continue being produced for as long as there will be electrons. – dim Feb 04 '20 at 08:32
    consider a CD4017 instead of a decoder, you can drive it with two lines. – Jasen Слава Україні Feb 04 '20 at 08:34
  • Good to know the discontinued info I ran across was bogus (or perhaps limited to one specific variant for one particular manufacturer!) – Toby Eggitt Feb 05 '20 at 00:26
  • Two years too late, but check out the flip-flop solution at https://electronics.stackexchange.com/a/607298/248767 for a really nice solution. There's also a simulation at https://electronics.stackexchange.com/questions/607231/what-resistor-network-topology-to-use-when-measuring-thermistors-in-a-battery-pa/607298?noredirect=1#comment1615849_607298 – Kenn Sebesta Apr 02 '22 at 22:38
Here's a problem, the 2N7000 has an \$I_{DSS}\$ of anything up to 1 uA on a good day and, depending on ambient temperature can be several tens or a hundred uA leakage: -
That current flows when the device is off and so, depending how many switched off channels you have will determine the volt drop error across R1. Given that R1 is 100 kohm and the thermistors are around 100 kohm I think this might be a serious cause of error.
Even 1 uA leakage from 2 devices might produce a voltage error across R1 of 100 mV.
Don't use individual MOSFETs use a multiplexer - you can get them with much lower leakage specified.
    Problem may be fixed in this way: switch off all mosfets and sample ADC - this value will represent "leakage temperature" of whole circuit. Next just subtract this value from following samples collected from thermistors. – ufok Feb 04 '20 at 09:44
  • @ufok this method only really works if we assume all MOSFETs have the same leakage current. – Andy aka Feb 04 '20 at 10:24
  • Nope. You will measure sum of leakage currents of all MOSFET at once (all V_GS are zero and all drains are connected to one point: ADC). – ufok Feb 04 '20 at 10:42
  • But, you need to know the leakage current of the device you want to use so that you can subtract it from the "mass" leakage current when making a measurement. In other words, you want the leakage from n-1 MOSFETs and, not knowing the contribution from them individually means you can only assume the currents to be identical. – Andy aka Feb 04 '20 at 10:44
  • Even when you asume that all MOSFETs are identical and has same leakage current, this current will leak through thermistors in different temperatures. So even known leakage current of all MOSFETs will contribute in different way into ADC voltage. If we asume zero leakage current and all MOSFETs are off, ADC will be equal to Vcc. With non zero leakage currents ADC will be equal to Vcc-offset. Knowing Vcc, R1 and offset you can calculate Rs (equivalent resistance) of all components below R1. Now when you measure resistance of any thermistor just subtract Rs from measured value. – ufok Feb 04 '20 at 11:17
  • @ufok may I suggest that you produce an answer to this question rather than let your thoughts reside as a comment at the bottom of my answer. – Andy aka Feb 04 '20 at 11:39
  • Hmm, that's clearly a potential issue. I suspect I shall build this and experiment (two reasons, one, required accuracy is really quite low; it's for preventing freezing in outdoor water bowls for animals :) and two, the learning will be valuable, particularly since I now know what to look for and can probably create tests deliberately to witness it. – Toby Eggitt Feb 04 '20 at 14:15
  • As a follow up question, do you have a suggested device? I found MC14052B but I'm not clear about the "analog voltage range" which it describes as 3~18V and < VSS. I think that means that the analog value mustn't exceed the supply rail, but if it means it doesn't work with analog voltages less than 3V, that would be a problem! Also, if there are cheaper or easier to obtain devices, I'm listening (and still researching). – Toby Eggitt Feb 04 '20 at 14:21
  • Or perhaps CD4051, readily available on Amazon? – Toby Eggitt Feb 04 '20 at 14:23
  • And a third "it'll probably be OK" I'd like to ask about. I was intending to calibrate these thermistors for their key temperatures (turn heater on, turn heater off) individually. Presumably, if I do that with the circuit fully populated, I would reduce the errors (though not eliminate, since the circuit temperature will vary wildly from say 10C down to "very cold, likely out of device spec range" on a bad day) while the water temps are more consistent. Is that fair understanding, even if not useful? – Toby Eggitt Feb 04 '20 at 14:36
    ADG1604 has low leakage. Only buy from reputable suppliers (not amazon) – Andy aka Feb 04 '20 at 14:41
Your approach is plausible.
  1. On state resistance is about 13 ohms. This is very unlikely to effect the expected temperature accuracy. At a very low current, the actual ON resistance will be still lesser.
  2. Provide sufficient amount of time after switching to the test channel and before scanning the ADC and a small value of capacitor at the input of the ADC. Since frequency of reading is in seconds, the sampling capacitor can charge well with in that time.
EDIT: if you can get hands on a 10k thermistor, the source impedance will be reduced to 5k at room temperature. The upper arm shall also be fixed 5k. This also reduces the effect of leakage current of the FET.
User323693
  • 9,151
  • 50
  • On 2) is this capacitor a Nyquist-Shannon thing, or for some other reason? I admit I hadn't thought of this, given that I'm expecting temperatures to change over minutes at the fastest. Perhaps more importantly, could you suggest a value range? Am I looking to make the time constant ... more than double the ADC conversion time? – Toby Eggitt Feb 04 '20 at 02:00
    Assuming 10pF capacitance, the external cap of 10 nF or a value nearby will help... – User323693 Feb 04 '20 at 02:29
  • Great thanks for that. When you say "10pF capacitance" is that referring to the input of the ADC itself? And is the goal simply to stabilize the voltage being read during the conversion? (This doesn't seem like a low-pass Nyquist Shannon thing from my reading between the lines). – Toby Eggitt Feb 04 '20 at 03:24
    @TobyEggitt the capacitor also limits the bandwidth for sure. The main goal here is to have no glitch during sampling. During the charge transfer to sampling capacitor (ADC) – User323693 Feb 04 '20 at 03:35
Good circuit.
For clean measurements, place a single 1uF capacitor at input to ADC. This cap, along with 50,000 ohm source resistance, forms a 0.05 second time constant.
Given, using the concept of NEPER where a neper is 8.6dB per time constant, if you want 86dB accuracy, you need to wait 10 time constants, or 0.5 seconds, after changing to a different sensor.
ohhh be certain the grounded side of the cap is tied to Vin- of the ADC, or to its AGND, or to its GND.
analogsystemsrf
  • 33,703
