i bought an expensive desk lamp from the US called Lumiy Lightsblade 1500s, i lost the power adapter, so my questions are as you are electrical engineers: 1) can i use it in israel (The standard voltage is 230 V and the standard frequency is 50 Hz.) ? does it lose its peak because the countries difference? 2) what power adapter should i seek for when buying?
Power supply Table from the website of lumiy
Yazan
  • 12V DC 2A, as it says on the label, but make sure the new adapter has the correct plug. Easiest way would be to buy a replacement from teh manufacturer. –  Jan 28 '20 at 15:02
    If you lost the power adapter..... you can't use it anywhere. If you are seeking product recommendations for a replacement, that subject is normally off-topic for this site. – Andy aka Jan 28 '20 at 15:12
Yes, you can use it in your country.
Specs allow you to use any power adapter which outputs 12 VDC and can supply 2 A or more current. You need to buy a correct plug that can work with your light.
Whiskeyjack
  • 7,946
  • 53
  • 91
