I have an inverter for cold cathode lights powered via a molex connector from a PC power supply, with a PCI/PCI-E slot bracket where is placed an ON/OFF switch, and I would need to use one light at a longer distance, exactly at a distance of 7 and half metres. There is a 2-pin connector leading to the inverter. From what I have read, cables leading to a cold cathode from the inverter hasn't to be long, so it seems like that the only option is by using a 2-pin extension cable. Can it be used like this and if yes, what wire I need to use for it? Assuming there isn't such extension available to purchase, can I cut the cable and solder the wires to create an extension?
Some more information:
Input voltage of the inverter: 12 V
Output voltage of the inverter: 680 V
Current draw: 5 mA
