I have a 12V 29.4W 3-wire Delta Electronics fan that I want to power using an EVGA 750 G3 PSU and control via one of the 4-pin fan terminals on an MSI MSI Z390-A PRO ATX LGA1151 motherboard.
Not considering the wattage of the fan, I originally plugged it into a (known working) fan terminal but it of course would not turn (and the BIOS correctly reported the RPM as 0). Connecting it directly to the PSU is simple enough, but this would result in it turning at full speed at all times.
I am curious if there is a "DIY" way that I can supply the fan with power from the PSU and control how much actually reaches the fan using the output of the motherboard (using something like an optoisolator to keep the motherboard safe).
The motherboard is able to control 4-wire fans using PWM, and 3-wire fans using DC voltage level.
Is there a product or combination of parts that will do this? I originally asked this on Super User, but it was deemed more appropriate here due to the involvement of DIY electronics.
Thanks in advance!
EDIT: The 4-pin connectors on the motherboard are indeed keyed to force correct connection of 3-pin plugs.
The BIOS includes a Fan interface that allows you to plot desired RPM vs temperature. Each fan output can individually be set to either PWM or DC voltage level control. The motherboard auto-detects what is plugged in (4 or 3 wire) and selects the appropriate setting, but it can be changed manually if desired.
The fan was not purchased through DigiKey, and came terminated with a keyed 3-hole connector (F). It also shipped with a 2-wire (but 4-wide) molex connector (M), unterminated on the opposite end.
Ctrl S
  • 103
  • Oops. I did not notice that the fan is a 3-wire fan. I assumed it was 4-wire. You can't do anything about its speed with a control signal because the motor driver buried inside the fan does not have a control input. You would have to actually change the supply voltage going to the fan. – DKNguyen Jan 22 '20 at 23:02
    Does this answer your question? [How can I adapt a 3-pin PC fan connector to a 4-pin connector?](https://electronics.stackexchange.com/questions/211795/how-can-i-adapt-a-3-pin-pc-fan-connector-to-a-4-pin-connector). Although that post talks about adapting control signal, all of the suggested solutions there can be powered by external 12V – Maple Jan 23 '20 at 02:52
  • Thanks for everyone's help! – Ctrl S Jan 23 '20 at 03:18
I did not see anything about 3-wire fan support on that page, but if user manual says so then you don't need anything else but correct wiring on 3-pin plug. The PWM control pin will not be used, and the taho output from 3-pin fan is compatible with tach input on 4-pin fan connector. Furthermore, 4-pin connector is usually keyed in a way that forces correct connection of 3-pin plug.
Note, that if motherboard does indeed support both types of fans then most likely you have to configure fan type somewhere in BIOS.
There is nothing "of course" about this. The fan should have been working at full speed all the time and motherboard should have been able to read its RPM. That's, of course, if it is configured for 4-pin.
From the link to a fan it seems it comes without a connector. So, check your wiring first.
UPDATE:
If your problem turns out to be insufficient motherboard output wattage, then one DIY solution would be to add OpAmp in voltage follower configuration, supplied directly from PCU and controlled by voltage output from motherboard connector. Depending on motherboard driver's design you might need to add a load resistor on the control line to simulate fan motor.
Maple
  • 11,755
  • 56
    The OP's implication is that the fan is much higher wattage than a typical computer fan. a 30W @12V draws 2.5A almost 20x that of a typical fan. – DKNguyen Jan 22 '20 at 23:01
  • @DKNguyen it is certainly on a high side, but we don't know what the motherboard driver is rated for. Without OP providing this info I can only assume that either wiring or BIOS configuration is incorrect. – Maple Jan 22 '20 at 23:08
  • Might want to add that the opamp voltage follower will need an external output transistor at that level of current. – DKNguyen Jan 22 '20 at 23:24
  • I am afraid @Voltage Spike found bigger problem - open collector output. I think by choosing this particular fan OP created nothing but problems. – Maple Jan 22 '20 at 23:27
  • I don't see the issue. The fan having a tach output instead of a speed control input on the third pin is irrelevant to your solution of just providing supply voltage to the fan that tracks the mobo analog speed control signal. – DKNguyen Jan 22 '20 at 23:30
  • The issue is that standard tach output is 5V signal. OP has to add pull-up to 5V to be able to use this fan's output – Maple Jan 22 '20 at 23:31
  • Oh, I see what you mean. – DKNguyen Jan 22 '20 at 23:32
  • Actually, I am wrong. According to many sources I just checked on the web, the standard output IS open collector. The pull-up should be on motherboard already. So no problems here. – Maple Jan 22 '20 at 23:37
  • @Maple I tried switching between PWM and DC in the BIOS and neither caused the fan to budge, not even with assistance. I later found out from online sources that the MB does not supply enough current to turn this size of fan. The other 3-wire fans seemed to respond to both DC and PWM, but I kept them on DC and kept the 4-wire on PWM. – Ctrl S Jan 23 '20 at 02:54
  • Ah, I see. Then see an update, I already accounted for that case. Also see the link in comments to OP – Maple Jan 23 '20 at 02:56
  • @Maple My fan did come with a 4-wide 2-pin molex-terminated cable (and the other end of the wire is unterminated)... other sellers of the same fan seemed to provide a much better molex cable. I feel like it's intended to be soldered to the red and black of the fan at its 3-pin connector, but that seems like it would be bad for the MB... – Ctrl S Jan 23 '20 at 03:01
  • @Maple Also, I apologize, I used a DigiKey link because it's a reliable source and supplied the most data about the fan. The fan was **not** purchased through DigiKey, and came terminated with a keyed 3-hole connector (F). It also shipped with a 2-wire (but 4-wide) molex connector (M), unterminated on the opposite end. – Ctrl S Jan 23 '20 at 03:45
Not with a 3-wire fan with a tachometer (TACH) output like the delta fan, the FG signal is for speed monitoring and it outputs a signal.
Source: https://www.delta-fan.com/Download/Spec/AFB1212GHE-CF00.pdf
One way would be to change the voltage which could be done with a variable resistor in series, but one problem with this is approach is the remaining power will be dissipated in the resistor. And with 24W you would have to be able to dissipate Watts of power in a resistor, which is not good.
A variable DC DC converter or voltage regulator might also do the job, the fan has a working voltage of 6-12V.
The best thing to do would be to get a fan with PWM control.
Voltage Spike
  • 75,799
  • 80
  • 208
What you have.
What you need to make it work. A 20A Pch FET.
  • The only problem with this is one has to crack it open and figure out a way to mod the PCB to split "+" between hall sensor and motor. Unless, of course you modify the schematics to put the FET (and probably large capacitor) _before_ power wire going in, leaving internal fan circuitry as is – Maple Jan 23 '20 at 02:42
  • Also, I might be wrong but the FET will probably not open with the voltage level of the PWM signal – Maple Jan 23 '20 at 02:50
  • It needs to have R pullup to 12V for OFF and low level to ON, so yes internal Mods – Tony Stewart EE75 Jan 23 '20 at 03:29
