I am in the middle of a custom PCB design using LPC1768
In fact that, this is an upgrade project from Atmega2560
I am using two LCD's from a shared SPI0
on LPC1768
When I was using Atmega2560, I had to use two series resistor (4.7K) in CLK
and SDA
lines.
I have wired two LCD's without adding resistors on LPC1768
and It seems to be working OK.
In the datasheet of LPC1768
, If I am not missed, I couldn't see anything mentioned regarding multiple slave devices on the SPI bus
Is there a rule of thumb on that or LPC1768 has some counter measures internally or I am too picky?
Thanks a lot for your inputs from now.
EDIT:
Sorry for the confusion. My Net-Names are not proper appearantly. I use a pin's other functions. In this case it is SPI.
SCK means SCLK
SDA means MOSI
