We are given a black box that contains only linear circuit elements and a pair of ports. We conduct the following two experiments with this black box.
  1. With the right port open, we applied V1 = 2V to the left port and measured I1 = 4mA and V2 = 8V.
  2. With the left port shorted, we applied I2 = -10 mA to the right port and measured I1 = 5mA and V2 = -10V.
Now we connect a current source to the right port and a voltage source to the left port. I1 = 8mA and V2 = 4V now. Find I2 and V1, in mA and V each.
I don't get this. Since we have analyzed the circuit separately for each source, adding them should give me the final values of I1, V2, I2, V1 etc. However, that's not quite true—from cases 1 and 2, I should have I1 = 4 + 5 = 9 mA, but it's 8mA. Hence, I thought that the black box consumes 1mA; hence I2 = 0 + (-10) - 1 = -11 mA. Similarly, V2 = 4V even though adding the V2 from first two cases gives -2; hence, the black box provides an additional 6V, and so V1 = 2 + 0 + 6 = 8V. However, this approach is wrong.
How might I solve this?
Mitu Raj
  • 10,843
singularity
  • 121
  • The applied voltage and current you need to find the results for are different values than were used for the tests, so you can't just add the test results together to get the final answer. – The Photon Jan 12 '20 at 15:53
  • @ThePhoton oh, I see why my method was wrong... but I still don't quite get how to approach the problem then. It seems that now I need to find what inputs were there given the outputs, but what information from the test cases should I use then? – singularity Jan 12 '20 at 15:59
  • from Case 1, I can get R1 = 2/4m and from Case 2, I get R2 = 10/10m. Since the resistances won't be changing (they don't explicitly say it's a varying resistor), given I1 and V2, I could solve for V1 and I2, getting V1 = 4 volts and I2 = 4 mA. Is this way of thinking right? – singularity Jan 12 '20 at 16:06
  • (I'm afraid that's a bit too simple, actually) – singularity Jan 12 '20 at 16:06
  • if the resistor is linear, that is explicitly telling you the resistance value doesn't depend on the applied voltage or current. But what are R1 and R2? There are no such elements mentioned in the problem. – The Photon Jan 12 '20 at 16:17
4 mA + 5 mA is what you would get if you applied 2 V on the left and -10 mA on the right.
But that isn't what you were asked. You were asked what happens if you apply 4 V on the left and 8 mA on the right.
So, to use superposition, first use test result 1 to find out what happens if you apply 4 V on the left (with the right port open). Then use test result 2 to find out what happens if you apply 8 mA on the left. Then sum those results to get your final answer.
The black box contains only linear elements. Therefore it can't "consume" any current.
Edit
OK, let me spell things out.
When they say the system is linear, it means you can write these equations for the unknown variables
$$I_1 = G_{11} V_1 + A_{12} I_2$$ $$V_2 = A_{21} V_1 + R_{22} I_2$$
where \$G_{11}\$, \$A_{12}\$, \$A_{21}\$ and \$R_{22}\$ are characteristic parameters of the black box that you need to discover. The names of the parameters are arbitrary, but you should think about why I might have named them what I did.
Your two test measurements give you enough information to determine the unknown parameters.
Then you can plug in any \$V_1\$ and \$I_2\$ you like (for example, the ones you were asked to solve for), and find the resulting \$I_1\$ and \$V_2\$ (for example, the result you were asked to find).
The Photon
  • 126,425
  • 159
  • 304
  • then is my approach as explained in my comments above closer to what you're telling me? – singularity Jan 12 '20 at 16:15
  • "So, to use superposition, first use test result 1 to find out what happens if you apply 4 V on the left (with the right port open)." that does give me 8mA (as was the final test case asked). – singularity Jan 12 '20 at 16:19
  • applying 8 mA on the left in Case 2 gives me 8V, which is double the given V2, so I2 = 4 mA as well? – singularity Jan 12 '20 at 16:20
  • @singularity, from test 1, 2 V applied on the left gave 8 V out on the right. So applying 4 V will not give 8 V out. It will give a different value that you can figure out because you know the system is linear. – The Photon Jan 12 '20 at 16:21
  • And case 2 applied -10 mA on the right, not +8 mA on the left. – The Photon Jan 12 '20 at 16:21
  • from your first comment here, does that mean I can use the relationship between the V1 and V2 (4 V1 = V2) and from Case 2, the relationship between I1 and I2 (2I1 = I2)? – singularity Jan 12 '20 at 16:23
  • which gives me V1 = 1 volt and I2 = 16 mA... – singularity Jan 12 '20 at 16:24
  • You can use the relationship between V1 and V2 to get the effect of V1 on V2. But to get the final answer you also have to add in the relationship between I2 and V2. – The Photon Jan 12 '20 at 16:27
  • are you saying that I can make use of the proportionality relationship between the voltages but not currents? – singularity Jan 12 '20 at 16:30
  • No, I'm saying when you do superposition, you have to consider the effect of both sources. That's what superposition means. – The Photon Jan 12 '20 at 16:31
  • I1 has a component proportional to V1, but it also has a component proportional to I2. You have to sum these together to get the final answer for I1. – The Photon Jan 12 '20 at 16:39
