30
I've been reading about the Voyager space probes and am very curious about how you design electronics and instrumentation for a very long life (40+ years) without any physical maintenance.
My guesses so far include:
  • Physical protection for components (sturdy metal box and potting compound)
  • environmental protection, keeping electronics warm and dry.
  • Redundancy (i.e. duplicates) where possible.
But what about the individual components themselves? How do you ensure a diode/transistor/capacitor actually lasts for that long? Or even harder, what about the (albeit primitive) microprocessors?
I guess under-rating components might help (i.e. using a 12 V capacitor in a 5 V circuit, or running a 8 MHz processor at 4 MHz, or using a 100 mA cable for a 1 mA current).
But there's got to be more to it than that? Or is this all part of the miracle of the probes, the fact that they're still working now?
MarkU
  • 14,413
  • 53
ConanTheGerbil
  • 923
    Space is a very harsh environment. I have devices that I built 40 years ago with no special care, that are still working fine today. My stereo has no power switch, so it has been running continuously for 40 years. I expect it will outlast me! – Bruce Abbott Jan 10 '20 at 18:01
    There is also a fair amount of component selection - e.g. "stay away from electrolytic capacitors at all costs". (Why don't you avoid them all the time? electrolytics die relatively quickly, but are good in other regards.) – TLW Jan 11 '20 at 03:12
  • Buy from AliExpress. Use RoHS solder. Use lots of capacitors. Those are the don'ts... – Harper - Reinstate Monica Jan 11 '20 at 05:42
  • What they said. Overlaps others in some cases. Do not use electrolytic caps. Do not use tantalum caps. Look to see if Rad Hard is liable to help (even if not in a radiation intense environment). Temperature derate to take advantage of (or avoid) [Arrhenius](https://wiki2.org/en/Arrhenius_equation) multiplier. Use a superb conformal coating. Vibration protect appropriately. Voltage derate excessively. – Russell McMahon Jan 11 '20 at 11:02
    [Why do most space probes survive for far longer than they were designed for?](https://space.stackexchange.com/questions/34212/why-do-most-space-probes-survive-for-far-longer-than-they-were-designed-for) – Mazura Jan 11 '20 at 13:01
  • What's the scope of this question (title = general, introduction = spacecraft, examples = general)? Spacecrafts or general? The Voyager's primary mission was about 12 years, that's nowhere near your asked 40 years. I think even operators and engineers involved in the Voyager program said they're amazed how long the probes lasted and it was never planned to operate them for 40 years. Also regarding Opportunity. – try-catch-finally Jan 11 '20 at 17:54
  • Radiation hardening is a biggie for long-lived space probes. "Cosmic rays", which are, for the most part, significantly attenuated by earth's atmosphere, can be quite dangerous to semiconductor components. – Hot Licks Jan 11 '20 at 18:14
  • Just a note, the electronics in space are in zero humidity and near zero degrees, if you check the optimum temperature for space electronics it would make conventional electronics last twice as long. every average 10 degrees reduces lifespan by 10% or something. the space electronics generates a few 100 wats of heat which is optimally cooled by heatpipes. – bandybabboon Jan 11 '20 at 18:59
  • @com.prehensible That's not really accurate. Sure, _space_ on average is cold, but your lump of metal outside our atmosphere in direct sunlight will get pretty hot pretty soon. – pipe Jan 11 '20 at 21:06
  • I totally agree, the ambient temperature of hubble is about -100 on the sun side and +150 on the cold side... cameras have a range of -30 to +50'C, solar panels are from -100 to 125, the older batteries survive at -5 to + 25, I believe that the average of the fascia of a satellite like hubble is lower than freezing point, perhaps -40 average. – bandybabboon Jan 12 '20 at 06:23
  • Most likely, in addition to everything else, NASA would have worked directly with the suppliers to take advantage of their internal expertise. Parts may even have undergone additional testing. They would not be ordering anonymously through digiikey. – user57037 Aug 07 '20 at 06:45
7 Answers7
27
You asked about Space probes specifically, but your question also had a more general flavour. I've addressed "how to make things last" generally. In space the eg AC mains aspects is vanishingly unlikely to be relevant - but power supply issues still are.
This answer is necessarily incomplete and overlaps other comments and answers in some areas. These are "out of my head". I my come back and add more later. Or not :
Longish ago I set out to build portable solar lights, mass manufactured in China, with a target lifetime of 20 years. That's what the client wanted. The client, the manufacturers and Murphy conspired against me at every turn. I failed. But managed to make some seriously robust products in the process. One of these days ... :-).
Not all of the following derives from the above experience. But, a fair amount is "informed" by it.
Do not use wet Aluminum electrolytic caps.
Do not use Tantalum caps.
  • OK - you CAN use Tantalum caps if you REALLY know what you are doing.
    As a starting point, do not use Tantalum caps.
Temperature derate to take advantage of (or avoid) Arrhenius multiplier.
  • A conformal coating MUST have low to no voids at PCBA surface, low dissolved water, low degradation in applicable environment, not produce damaging degradation products and/or scavenge degradation products.
ALL coatings pass water vapour. Two factors can help immensely.
  • Having an essentially void free surface against the PCBA and
  • A coating with a low dissolved water content so that there is minimal liquid water in the coating
combine to allow the concentration of water reaching the surface to be very low and reaction rates are accordingly reduced.
  • As an example of degradation products and scavenging. Glass fronted PV (solar) panels have minimal water transmission through the glass (no surprise). The industry standard bonding material is EVA plastic which is heat and pressure polymerised to form an essentially clear void free adhesive layer between glass and PV cells. Over a decade plus gradual UV attack produces products which enhance cell corrosion. Modern glass front sheets contain scavengers to absorb these reaction products. Lifetimes of 30+ years are "easily enough" obtained. [I have an old tired but still operating BP 50 Watt PV panel more than 40 years old].
  • Parylene is king but not the only answer (See Here and Here ). Use the right PArylene - it's a family and some suit some areas better than others.
    Dow Corning* 1-2577 and family are "pretty good".
Do not rely on bonding agents to hold things together or in place.
  • Acid-free-cure Silicone Rubbers give 20+ years service if properly matched to surfaces. They may last 30 or 40 years, or more. Do you trust anyone to guarantee this to be the case.
    Surface materials matter - experts will tell you what's needed for tricky surfaces.
    But, not relying on binding agents is better.
  • Be aware that while ferrous materials have a lower stress limit below which fatigue failure does not occur, non-ferrous metals have NO LOWER STRESS LIMIT below which fatigue failure will not ultimately occur. So eg an Aluminium bracket that is stressed to well below its tensile limit may still fail after say 35 years if stressed repeatedly to some lower limit.
Voltage derate excessively in areas where appropriate.
DO NOT voltage derate where inappropriate.
  • eg the wet Al ecaps that you are NOT using should not be run vastly below voltage spec.
Be aware of ceramic cap attributes that may hurt you.
eg voltage ringing on voltage steps, microphonic and major voltage spikes from apposite vibrations.
Be aware of corrosion mechanisms.
  • Some coatings provide electrochemical sacrificial protection of underlying metals.
    Some don't.
    Some are worse long term than no coating!. eg zinc "galvanised" coatings protect underlying iron/steel by being more active electrochemically.
But eg Nickel (or the now far less often seen tin) do NOT provide electrochemical protection - rather just the opposite. These coatings provide mechanical barriers to corrosion products. If / once / when the coating is breached over a small area an electrochemical cell is formed that selectively targets the underlying layer and the small area exposed means the corrosion rate is higher than if the while item was NOT plated (!).
In any case - DO NOT USE TIN COATINGS - see below
Do not use Tin coatings
  • Tin is nowadays renowned for growing whiskers on surfaces - sometimes at fast rates and sometimes with astounding lengths. In some cases whisker growth takes decades and is unimportant. In other cases failures can occur in very short periods (say under one year).
    At least one communication satellite is believed to have been lost due to tin whiskers.
  • I have some extremely old relays. Some of their metal surfaces are smooth to the touch. Other portions are extremely rough and the sprouting tin whiskers are clearly visible.
Be aware that EMI matters.
  • EMI (electromagnetic interference) at usual levels can be formally designed against. If you know with certainty that nobody is going to operate a 1 kW linear amplifier, unshielded Magnetron, high energy spark source, .... within a critical distance of your product for the next 40 or 50 years then you may decide to not protect against such. If you are not certain of this then protection may be in order.
Be aware of worst worst worst case mains and power supply issues.
  • A very long life device will usually have external energy supply. Typically mains AC, battery charged from some external source of maybe solar. Just maybe thermal, radioactive, ... .
  • If your mains input at eg 110 VAC oe 230 VAC will NEVER have an 11 kV line dropped onto its feeder in the next 40 years then you may not wish to protect against such a possibility. I occasionally hear of telephones leaping off walls or houses bursting into flames when this happens. It's rare. It happens. There is a limit to what you can choose to protect against. You have to choose what the limit is.
  • Lightning happens. In two years I lost 2 multifunction printers to lightning strike nearby in a residential area not known for overly much lightning activity. After the second I decided that having a fax line connected to my printer was overrated. No telephones were damaged.
  • Mains energy spikes can be "very enthusiastic". There are standards to be met to protect against such. Murphy does not care about standards.
Use only utterly reliable suppliers and ensure provenance for all parts sources.
  • These overlap. In some cases you may be dealing directly with suppliers or middlemen.
  • Be sure you know the standing of the entity you are dealing with. In Asia a supplier purporting to be the manufacturer may in fact be reselling product from elsewhere.
  • Factory visits help, but, do not be fooled. (I have been). And ensure that products which come from a given source continue to come from that source.
  • Name brand products with a good reputation will often be counterfeited. Be sure that what you receive IS from the claimed manufacturer. [eg GP (Goldpeak) AA NiMH (and other) batteries are relatively unknown by that name in the est - but GP are one of the largest battery makers in China. So much so that pirate GP lookalikes abound.
  • You do not HAVE to buy from a supplier who jealously defends their reputation (Digikey, Mouser, ....) or products from manufacturers of impeccable standing, but it certainly helps.
  • If you have to source a product and do not have time for adequate due diligence or source checking, if Panasonic make it, buy Panasonic. (That's sort of with a :-) - but I'm also serious. I have zero financial or business links with Panasonic, but I don't recall them ever doing other than superbly in any area they choose to touch).
Learn how Murphy works.
  • If something can go wrong it will.
    If you know that something can't go wrong Murphy will do his utmost to prove that your knowledge is false. Look at every possible multi-factor failure mode, and as many impossible ones that you can manage.
Impossible series of faults or conditions are not as impossible as we'd like
  • A large proportion of major disasters occur when 3 or 4 or 5 almost impossible events occur simultaneously. This happens often enough that 'you'd think that people may have noticed' - but people seem not to.
Russell McMahon
  • 147,325
  • 210
  • 386
    Wow. Nice answer. But let me recap it In a word: money. – Sredni Vashtar Jan 11 '20 at 21:46
  • @SredniVashtar Money often helps :-). In some cases it costs much more and in others only somewhat more. eg if you MUST use aluminum wet electrolytic caps lifetime ~~= Liferatedrated x 2^((Trated-Tambient)/10) - ie Life rated is at rated temp which is always rather higher than actual . Caps are often 85C or 105C rated. 105-85 =20C . Increase in lifetime at same temperature = 2^(20/10) = 4 x. 105C caps are dearer but with care often not vastly so. | Now place the caps intelligently and channel airflow well and you get – Russell McMahon Jan 16 '20 at 06:35
    ... 2x lifetime per 10C reduction in mean temperature. In some cases heatsinking the caps (who ever heard of it? :-) ) can help. So if you say use 105C caps and reduce ambient by 10C by careful design then you increase lifetime by a factor of 4 x 2 = 8 . THEN look at actual ambient. If after redesign it's say 35C max and not too too much less mean then (105-35_ = 70C. 2^7 = 128 x. A 2000 hour cap will last (notionally) 2000x128/8765 hrs/year = 29 years. If you can get t_mostly down to 25C that's 58 years and you notionally meet the 40 year design aim. Notionally :-). – Russell McMahon Jan 16 '20 at 06:36
  • Brilliant Answer Russ. *Murphy does not care about standards.* LOL – Tony Stewart EE75 Aug 06 '20 at 01:43
  • About tin. Keep in mind that whiskers are avoided by including a few percent of lead in the tin. Of course, now you have lead in your product, so maybe that's not a great idea, either. – WhatRoughBeast Aug 03 '21 at 02:24
  • @WhatRoughBeast As long as what happens in the product stays in the product lead may be acceptable. If it is meant to last 40 years then this may be an acceptable constraint. – Russell McMahon Aug 03 '21 at 10:33
  • Actually, the ROHS movement is giving the hi-rel people fits. After the danger of tin whiskers was appreciated, lead-doped tin plating was the preferred plating material for space equipment, Can't get it any more. – WhatRoughBeast Aug 03 '21 at 11:57
25
In a nut shell, quality, quality, quality.
The first thing you do is to use high reliablity parts. NASA specifies 4 quality levels starting with commercial (the lowest grade), moving to '883B (a mil standard); then QML level Q, and finally QML level V. With each step up in level, the screening requirements become more stringent; the paper trail more onerous; and the cost ever increasing.
With increasing quality levels comes lower predicted failure rates. This means that when you do your reliability prediction (or more accurately, your probability of mission success), your Ps increases with better quality parts.
Adequate derating also plays into this, particularly with new technology or new parts for which there is no history. We are sometimes told to use a 100 V MOSFET for a 20V application because of this.
Redundancy helps a lot. But with redundancy comes added complexity and more parts, which actually degrades the serial failure rate.
With any hi-rel design, you need to do an analysis to identify and mitigate, to the extent possible, any single point failures (SPfs). An SPF is a failure that would degrade or cause the loss of the entire function, or mission. SPF analysis is particularly important when redundancy is employed because you do not want a single failure to cause both the primary and redundant set of hardware to not work.
Finally, on those Voyager missions, I'll bet they were designed for an 8 or 10 year mission life, not 40.
Edit 1:
While you cannot test your way into a highly reliable system, testing plays a big part in weeding out marginal parts. All of our assemblies go through some type of environmental stress screening, which includes functional testing over the expected temperature range, and temperature cycling, both powered and un-powered. Systems destined for space go through testing in a thermal vacuum (TVAC) chamber. There also may be vibration or shock testing, but these are usually done on a test article.
EDIT 2 8/6/2020 - Added blurb on temperature swings
Several who have responded to this question mentioned temperature and its effects on reliability. So I thought I would expound on this a bit more.
Semiconductors exhibit a failure rate that approximately doubles for every 10 deg C increase in temperature. There are papers out there arguing whether 2X is the right value; that maybe it should be 1.8, or 2.5, or some other amount. But for purposes of this discussion I’ll use 2X as it is a value that’s “accepted” by industry, the government, and the reliability disciplines.
With that out of the way, it makes sense that, from a reliability standpoint, you want to keep your electronics as cool as possible. 85 deg C operating temperature is better than 95 deg C, and 75 deg C is better than 85 deg C.
But in addition to the operating temperature, be it average or peak, there is also the temperature swing, or variation. Temperature swings are bad from a reliability standpoint in that it is temperature changes that stress interconnects, particularly those involving IC’s or even discrete semiconductors. These temperature changes induce a stress on the interconnect between the component and the board due to the differences in Coefficients of Thermal Expansion (CTEs) between the component and the board. For example a typical FR4 PCB has a CTE of ~15 ppm, while a BGA package might have a CTE closer to 6 ppm. These differences in CTE cause a stress to be exerted on the solder joints that attaches the part to the board as the temperature changes. These stresses are proportional to the changes in temperature and the size of the package and over time, given enough temperature cycles, can lead to a fracture of the solder joint or attachment to the board.
Leaded parts, such as the old 14/16/20 pin flat packs are much more forgiving in this environment than are rigidly attached packages such as Ball Grid Arrays (BGAs) because the leads of the former provide a significant amount of compliance that reduces the stress on the solder joint.
The reason for bringing all this up is that what we usually care about is the reliability of the system as a whole, or more properly the Probability of Mission Success (Ps) of the system. Because of how temperature changes and the average operating temperature affect various aspects of the system’s reliability, it may turn out that it’s better to operate a system at a constant higher temperature (say 85 deg C) as opposed to letting the temperature swing from 10 deg C to 70 deg C on a regular basis.
SteveSh
  • 9,672
    Yes. Although you can't "test in" reliability, you can test each component for unreliability. I think a crucial part of this is **high accelerated life testing**, which weeds out components that won't last for 10 years. – Elliot Alderson Jan 11 '20 at 13:09
    You are correct about single points of failure. Even the most sophisticated redundant systems have a small core where a single point of failure can bring down the entire system. For example, in triple modular redundancy, it is the voting circuit that must never fail. – richard1941 Jan 17 '20 at 04:07
12
I recall a business called Continental Testing Laboratories. They had the first computer I ever used. Punch cards existed for EACH resistor, capacitor, transistor, diode, that went thru the test/heat/test/heat/test/heat, where the parameters were examined for DRIFTING.
Components that DRIFTED differently from the other components were discarded.
They also XRAYed the components to look for voids and for foreign particles.
With all this, a 1 cent resistor becomes 100 cents, and has a small tag attached, so the final circuit documentation describes the recorded parameters for each component.
Transistors are assumed to track if they are differential_pairs inside a 6-lead metal case (such as 2n2020, if I recall rightly). Thus neutron bombardment in orbit is assumed to degrade the Beta of each transistor equally, and the "matching" is maintained.
The V_base_emitter is assumed to not perfectly drift, thus a design margin for offset voltage becomes part of your worst-case-design analysis (slide rules were used).
To implement anything better than about 8 bit or 10 bit ADCs is not possible using the allowed discretes. I think BurrBrown or TRW may have produced metal_hybird DAC networks that were shown adequately stable for decades.
Additionally, the team I worked in was allocated a THERMAL ENGINEER; he used finite element methods (on an IBM 1630) to model the heat flows.
Since the applications were space-borne, the allocated powers were SMALL, and a simple ground plane to a mounting stud (or 4 or 6 of them, to handle shock) was all that was needed to let heat flow out of the circuit/PCB/module to the spacecraft chassis and then radiate out into space.
To prevent freezing the spacecraft, I've heard shutters are used, these regulating how much of the spacecraft is actually exposed to the coldness of space.
================================ Aug 6, 2020
Specifically following up on answer of SteveSh and the paragraphs on heat
  • having embedded PLANES for Ground(s) and for VDD(s) are excellent.
  • though FR-4 is poor heat conductor (its glass and glue), adjacent layers of Planes will easily exchange heat, especially if has 4 layers or 6 layers in total 1/16" thickness. Thus the Power planes become as useful as the Ground planes for heat removal.
  • You can use thicker copper foil, to drop foil's R_thermal by 2:1 or 4:1
  • Example: 1 watt (MCU?) of size 1centimeter, in middle of 9_cm board with copper beryllium card_cage_slides on 2 of the 4 edges, to remove heat. That 1cm^2 footprint has EIGHT surrounding 1cm squares (in a 3 * 3 grid). If the only plane is Ground (example), then removing the heat will be at most 70 ° C per watt per square divided by 8 (the EIGHT heat exit paths), or 8 ° C per watt.
  • But the heat is not yet at the edge of the PCB (where the card_edge_slides will remove heat to the spacecraft chassis.
  • This is a 9cm by 9cm PCB. Model it as large squares, each 3 * 3 cm; thus we now have a new grid, fully filling the PCB. The middle square is our heat source. Assuming the heat flows left and right to the card_slides, we can use SIX of the 8 large squares as heat removal (the 2 squares at center top and bottom do not contact the card_slides). With 6 squares of heat removal, the additional heat flow resistance is 70/6 = 11 ° C per watt.
  • Thus the R_thermal, from the 1cm MCU to the edges of the 9cm by 9cm PCB edges, is 9 + 11 ° C per watt, or 20. This assumes the MCU easily dumps heat into at least one PLANE.
  • Thicker foil will drop this. More planes will drop this.
analogsystemsrf
  • 33,703
  • When I was an Aerospace Instrumentation Design Eng, in the 70's my Mil-Std-883B Burr Brown hybrids failed yet the Industrial versions met linearity specs. The only difference I read was the X-Ray inspection. But I suspected a change to conductor gnd [impedance paths] – Tony Stewart EE75 Aug 06 '20 at 02:06
As a matter of fact, NASA PCB design guidelines addresses your question. Further to PCB, NASA Workmanship standards covers things like wire preparation, crimped terminals, discrete wiring, cable harness etc.
A sample extract from Section-6
NASA Workmanship Standard Section-6
FlegmatoidZoid
  • 511
The Voyager mission was a major event in the history of FAULT TOLERANT COMPUTING with its STAR (self test and repair) computer. The computer would monitor its own performance, check for errors, and test itself comprehensively from time to time. Any module found to be defective would be replaced with a spare. I do not know how far this process has gone, which modules have been replaced, or what the spare inventory presently looks like.
The computer architecture is way more complex than mere triple or quad redundancy.
If you find a text on FTC, you are likely to find a discussion of the STAR computer and its reliability model.
richard1941
  • 632
Calculating MTBF would probably be the best way to do this. De-rating components is one way to increase MTBF.
EE_socal
  • 1,392
    MTBF is different from lifetime. Electrolytic caps can have a very long MTBF with a much shorter lifetime for example. MTBF is useful, but lifetime has to be taken into account as well. – John D Jan 10 '20 at 19:02
    This is also not actionable. – James McLeod Jan 11 '20 at 12:50
I would recommend a conformal coating like Parylene.
Parylene Conformal Coating
Parylene is considered by many to be the ultimate conformal coating for protection of devices, components and surfaces in electronics, instrumentation, aerospace, medical and engineering industries. Parylene is unique in being created directly on the surface at room temperature. It is chemically stable and makes an excellent barrier material, has excellent thermal endurance, as well as excellent mechanical properties and high tensile strength.
  • There is no liquid phase involved. Coatings are truly conformal, of uniform controllable thickness, and are completely pinhole-free at thicknesses greater than 0.5µ.
  • Parylene coating completely penetrates spaces as narrow 0.01mm.
  • No initiators or catalysts are involved in the polymerization, so the coating is very pure and free from trace ionic impurities.
  • Room temperature formation means the coatings are effectively stress-free.
  • Parylene is chemically and biologically inert and stable and make excellent barrier material.
  • Parylene is unaffected by solvents, have low bulk permeability and are hydrophobic. Coatings easily pass a 100hr salt-spray test.
  • Parylene has excellent electrical properties: low dielectric constant and loss with good high-frequency properties; good dielectric strength; and high bulk and surface resistance.
  • Parylene has good thermal endurance: Parylene C performs in air without significant loss of physical properties for 10 years at 80°C and in the absence of oxygen to temperatures in excess of 200°C.
  • Parylene is transparent and can be used to coat optical elements.
  • FDA approval of parylene-coated devices is well-documented. The coatings comply with USP Class VI Plastics requirements and are MIL-I-46058C / IPC-CC-830B listed.
  • Parylene coatings are completely conformal, have a uniform thickness and are pinhole free. This is achieved by a unique vapor deposition polymerization process in which the coating is formed from a gaseous monomer without and intermediate liquid stage. As a result, component configurations with sharp edges, points, flat surfaces, crevices or exposed internal surfaces are coated uniformly without voids.
  • Parylene coating provides an excellent barrier that exhibits a very low permeability to moisture and gases.
  • Parylene coating has excellent mechanical properties, including high tensile strength.
  • Parylene is stable over a very wide temperature range (-200 ‘C to +200 ‘C), allowing the chamber items coated in Parylene to be put in an autoclave.
Nikk
    Why do we care about FDA approval or putting items in an autoclave? It appears to me that you just copied a sales brochure into your answer. – Elliot Alderson May 11 '20 at 17:39
