I try to design circuit that convert 10 bit binary to BCD with 74185 IC in Proteus, but when i run this project output of this IC like this attached picture is unknown(IC don't work! and i didn't receive any error!) and I did active enable. why? and how can give suitable output?in this attached image i test enable with a logicProbe and change it but still IC don't work.
In this attached image i try to convert 5 bit binary to BCD and i test enable input with a LOGICPROBE and change it, but still IC don't work.
EDIT like this link i use from resistor network and all output were 1. Weird ULN2003 to 7-segment behaviour in Proteus enter image description here
Reyhane
  • Can you post a screenshot of the device when you search for it in the parts list? It may be that it doesn't have a SPICE model, hence having undefined outputs, and using pullup resistors will make them all high. – MCG Jan 14 '20 at 13:14
Outputs of 74185 are open collector.
