I am constructing a circuit to drive a powerful LED that requires about 10 amps at 12V. I also have a battery that happily supplies that. For obvious reasons, that LED requires a cooling fan, and I've chosen one that takes 0.05 amps at 12V. How can I run this fan with the existing circuit?
EDIT:
I will probably be using a boost converter to control the current. It will be boosting from ~10V to the 12V required for the LED. I will also be using it to dim the LED.
Specifications for the boost converter:
- Input: 8.5-50V, 15A max
- Output: 10-60V, 12A max
