edit: diode is replaced with 1n4148
While designing such a peak detector, what should be the approach of choosing C and R values? Which specs of the detector will be based on them? I assume their values will be depending upon the frequency of incoming signal, and related to time constant of RC network. But, I need some better understanding.
muyustan
  • 2,046
  • Do you know how to choose the reservoir capacitor in a half wave AC power rectifier? Unless you’re interested only in frequencies less than a few hundred Hz, don’t use the 1N400x series of diodes. – Andy aka Dec 17 '19 at 17:55
  • @Andyaka so I should go with a fast-switching diode like 1n4148? And no, I don't know even what a "reservoir capacitor" is. – muyustan Dec 17 '19 at 18:08
    You should find some good google info on power rectifiers and choosing capacitor values. It’s exactly the same principle. Yeah I know you want a direct answer but.... – Andy aka Dec 17 '19 at 18:14
    1N4148 is a good choice for anything sub tens of MHz. – Andy aka Dec 17 '19 at 18:15
  • @Andyaka thanks, I will look into them. My frequency of interest is 1-2 kHz, so 1n4148 will do the job then. – muyustan Dec 17 '19 at 18:16
    https://electronics.stackexchange.com/questions/100518/rc-time-constant-and-diode-detector – Bruce Abbott Dec 17 '19 at 22:36
0 Answers0
