I have laptop (Acer Aspire 7745G) which has charger 19V-4.74A and battery 11.1V - 6,6Ah (73Wh). I'm planning to buy powerbank for it but I don't know what voltage would be okay. I'm looking to this powerbank I see that it has DC output of 12/15/19V. So, can I use this powerbank for my laptop? If yes, what voltage of output should I use?
Asked
Active
Viewed 105 times
I want to use it as replacement of battery because there are no battery for my laptop which has more than 100Wh. – Pranciskus Dec 12 '19 at 19:26
Laptop internal charging and power supply circuitry will PROBABLY require voltage about the same as the charger, NOT the bttery. – Russell McMahon Dec 12 '19 at 19:30
@RussellMc Thanks, I thought the same just wanted to be sure. – Pranciskus Dec 12 '19 at 19:32
Does this answer your question? [Choosing power supply, how to get the voltage and current ratings?](https://electronics.stackexchange.com/questions/34745/choosing-power-supply-how-to-get-the-voltage-and-current-ratings) – Voltage Spike Dec 12 '19 at 21:35
You almost certainly will not be able to replace a specific laptop's battery with a "power bank". The motherboard will not recognize the power bank as a valid battery, so it will not attempt to charge it. There is a communications protocol between the motherboard and the battery, and the exact nature of the messages is usually not public.
Elliot Alderson
- 31,192
- 5
- 29
- 67
But if I have battery removed and maintaining with powerbank which is connected to DC port, so, computer will work, yes? And if I put battery back to laptop it will not charge, right? Even if it will not charge battery, is it dangerous to have it inserted while maintaining with powerbank? In your answer "so it will not attempt to charge it" do you mean charging laptop or battery? – Pranciskus Dec 12 '19 at 20:06
Sorry, I don't understand what you are trying to say. What "DC port" are you talking about? How can the battery be "inserted while maintaining with powerbank"? I can't figure out what is being connected to the powerbank and what is being connected to the battery. – Elliot Alderson Dec 12 '19 at 20:13
By saying "DC port" I mean laptop charging port. Maybe It's called AC, ain't sure. – Pranciskus Dec 12 '19 at 20:31
By saying "inserted while maintaining with powerbank" I mean, while original battery is in its slot, using external powerbank which is charged and turned on and connected to laptop's charging port. – Pranciskus Dec 12 '19 at 20:34
