Problem: How to quickly and cheaply test if a given BMS (Brand: Daly / Tiny BMS / etc) or battery-powered system behaves as intended for various cell voltage combinations without waiting for actual cells to (dis)charge. For example, if one cell voltage drops w.r.t the others, then this unbalance should trigger the BMS to take some predefined protective action.
Background: I want to use sixteen 206Ah 3.2Vnom LiFePO4 cells in series. I do not have the background to design or quickly understand circuits with many inductive or capacitive components.
Conceptual idea: Use an array of buck converters (e.g. this one) as shown in the figure. To reduce the voltage, for example, of only emulated cell 3 (\$\Delta \mathrm{V}_3\$) with 0.2V, both buck 4 AND 3 have to be decreased by 0.2V.
Question: Will this work without destroying the BMS, assuming proper wiring, generally speaking? Also if the BMS starts passive balancing? If not, what adjustments would you recommend?
