Imagine I build the below LED driver circuit where I know all the component parameters such as 2V LED forward drop and resistors and Vcc and Vbb as in the following diagram:
And if I only dont know the beta of the NPN transistor; how can we estimate the required minimum beta for hard saturation?
In hard saturation Vce will be zero? So Ic= 9mA.
Ib = 0.9mA.
Does that mean a beta of 10 suffice for hard saturation??
GNZ
  • 1,559
  • 52
  • Read this https://electronics.stackexchange.com/questions/311243/bjt-base-current-calculation/311306#311306 – G36 Dec 01 '19 at 20:18
    You could just assume things. Or you could go look at the datasheet for the BJT. The datasheet will usually include a diagram/chart that specifies a saturated \$\beta\$ when attempting to show you the base-emitter voltage vs collector current curves. It will be up in a corner of the graph somewhere. That figure usually can be taken as "acceptable" for use. But for small signal BJTs, anything less than 20 pretty much guarantees deep saturation. For a 2N3055 running at high collector currents a very low value is needed. Again, look to the datasheet. They almost always provide enough clues there. – jonk Dec 01 '19 at 20:18
  • But of course, the circuit itself also has to be taken into consideration, since saturation isn't only within the BJT but is also about what's surrounding it. – jonk Dec 01 '19 at 20:19
  • @jonk Should I look at Figure 3? https://www.onsemi.com/pub/Collateral/2N3055-D.PDF In my case Ic= 0.9mA. At 25 centigrade it shows a beta of 90. Is that correct to estimate beta for saturation? – GNZ Dec 01 '19 at 20:27
  • Oh but it says for Vce 4V. I need for saturation – GNZ Dec 01 '19 at 20:28
  • @Genzo For a collector current of about 1 mA, you DO NOT want the 2N3055!! You will want a cheap small signal BJT (PN2222A, etc.) But yes, Figure 7 on that datasheet suggests a number to use for saturation. The bottom curve there is the Vce(sat) curve and that's what you should look for, also. – jonk Dec 01 '19 at 20:33
  • I see it says 10 for beta at 1mA Ic – GNZ Dec 01 '19 at 20:37
  • But which voltage is the horizontal line at Figure 7? – GNZ Dec 01 '19 at 20:39
  • Beta = 90 at some point well away from saturation, like Vce=4V as you noticed. At lower Vce, beta reduces. Many transistor data sheets take beta=10 as their definition of the saturation point. So, yes. –  Dec 01 '19 at 21:01
  • Simply use the beta = 10 and do the calculation Rc = (15V - 2V)/10mA = 1.3kΩ and Rb = (15V - 0.7V)/1mA = 14.3kΩ so use Rb = 10kΩ resistor and you done. On figure 7 you have current in amps, not in mA (from 0.1A to 10A). Also the Vce(sat) for 1A is eqequal to 0.1V and Vbe(sat) = 0.78...0.79V – G36 Dec 01 '19 at 21:10
Let's start with your circuit and play around with it a little bit. Beforehand, let's create a "model" for the LED. Not a complex one. Just a really simple one. But one that is complicated enough to highlight a few ideas.
Suppose that the LED voltage is: \$V_\text{LED}=1.8\:\text{V}+I_\text{LED}\cdot 20\:\Omega\$. The idea here is that \$I_\text{LED}=0\:\text{mA}\$ when \$V_\text{LED}\le 1.8\:\text{V}\$ and that \$V_\text{LED}=2.0\:\text{V}\$ when \$I_\text{LED}=10\:\text{mA}\$, etc. This is a simple, but not overly-simplistic model for an LED operating near its designated operating current. I'm creating this model for you because of what's coming ahead. So bear with me.
Now, let's take your circuit with two resistors and discuss it in several circumstances:
The first two on the left are saturated. The reason is that the collector resistor is large enough to cause a sufficient voltage drop, together with the LED drop, to force the collector voltage to its VCE(sat) value. When that happens, the collector resistor determines the LED current.
I wanted to create a slightly more complicated LED model above, because I didn't want to make this too easy for you. Let's take the left-most case. An overly simple calculation using \$V_\text{LED}=2.0\:\text{V}\$ would suggest that \$I_\text{LED}=\frac{15\:\text{V}-2\:\text{V}-200\:\text{mV}}{1.5\:\text{k}\Omega}\approx 8.53\:\text{mA}\$. But the fact is, the LED voltage will be a little less than expected because of its model. And because \$V_\text{LED}\lt 2.0\:\text{V}\$, we can expect slightly more current. But still, \$R_2\$ does limit the current in the LED in the left-most example.
How do we know that the left-most circuit is saturated? We know because \$\beta=100\$ in active mode. But this would suggest a collector current of \$95\:\text{mA}\$ and that would cause \$R_2\$ to drop \$142.5\:\text{V}\$. We know this is impossible! So the BJT must be saturated.
Next towards the right is still a circuit that is saturated. Again, a simple calculation would suggest (if it weren't saturated) that the voltage drop across \$R_2\$ would be \$20.9\:\text{V}\$. And again, we know that's impossible. So the circuit must be saturated. A simplistic estimate of the current (without the fancy LED model mentioned above) would be \$I_\text{LED}=\frac{15\:\text{V}-2\:\text{V}-200\:\text{mV}}{220\:\Omega}\approx 58.2\:\text{mA}\$. But because the LED is dropping not quite \$3\:\text{V}\$ (using our fancier model), we find that the actual current is slightly less (as shown in the schematic.) Still, \$R_2\$ does closely limit the current in the LED.
In the 3rd case from the left (2nd from the right), we are no longer saturated. Now, we are limited by \$\beta=100\$ for the BJT's active mode. We can easily tell by noting that the voltage drop across \$R_2\$ using the maximum \$\beta=100\$ provides a voltage drop of \$9.5\:\text{V}\$. The LED itself drops \$3.7\:\text{V}\$. So the collector voltage is \$1.8\:\text{V}\$, which is definitely not a saturated collector voltage here. This means we can use \$\beta=100\$ for the calculations, since that's the maximum \$\beta\$ for this BJT. What's limiting the current in the LED now is the BJT's \$\beta\$. No longer is \$R_2\$ playing any part in it.
The 4th case (right-most) is similar. I've just further lowered \$R_2\$ to make the point still more obvious. The current in the LED is still limited by the BJT's \$\beta\$.
Note that in the last two cases (the right-most two cases), the current in the LED depends upon the BJT's active mode \$\beta\$. Since this varies from BJT to BJT, these two right-most circuits are not managed well. The LED current will depend a great deal on the specific BJT, it's temperature, etc. So these are not "good" switch circuits.
Note also that the 2nd from the left schematic is pretty close to active mode. It's still saturated. But it's getting close to the maximum allowed by the active mode \$\beta\$ of the BJT. \$\beta=\frac{54.2\:\text{mA}}{950\:\mu\text{A}}\approx 57\$. The value of \$R_2\$ is still performing its "current limiting" function, but it's getting too close to not performing that function.
This is why the left-most circuit is considered better. Here, \$\beta=9\$ (go ahead and check.) And this design is very safe because it's a long ways away from entering into active mode. Note also that the simplified calculation for the LED current is closer here than it is in the circuit that is 2nd from the left, despite the fact that it is still a saturated circuit.
Pushing \$\beta\$ lower is usually good, when operating the BJT as a switch, because it keeps you further away from active mode. The further away you are, the better. But of course, you also have to keep in mind how much extra base current is being wasted (which adds to power, as well.) So there is always a "balancing act" here. Where exactly you decide to strike that balance is your choice.
jonk
  • 77,059
  • 73
  • 185
