This picture is given in my textbook regarding an n-p-n transistor circuit:
Why is the emitter grounded? Why can't it be directly and only connected to the negative terminal of Vcc?
Also, what is the use of defining a voltage reference point?
All voltages are relative, a concept which a lot of people have trouble understanding.
It is rather common to say that "at Point A we have X Volts" but actually it is wrong!
Officially you should say "Between point B and point A we have X volts".
As that become tedious it is easier (common) to define a reference point. Then if you say "at Point A we have X Volts" your are actually saying "Between the reference point and point A we have X volts".
The next step often used in a schematic when defining the reference point is to use the ground symbol for that.
In most circuits the Ground symbol just indicates the point in the circuit that we will call "Zero Volts". It rarely indicates an actual connection to the earth.
In your circuit, "Ground/Zero Volts" is connected to the negative terminals of the Vcc and Vbb supplies. Voltages eleswhere in the circuit are measured relative to "Ground/Zero Volts".
