This is as much a software question as it is electronics question, but here we go. I am very new to STM32 micro controllers and I've been sitting with this problem for the last 3 days of so
My goal: send a string using CDC_Transmit_FS(string,sizeof(string));
from a STM32F401RE (NUCLEO Dev board) to PC via Full Speed USB through Virtual Com Port.
Problem: PC does not recognize STM32 as a Full Speed USB device. Fails to enumerate it.
Here is output from sudo dmesg
[87338.796874] debugfs: Directory '27' with parent 'devices' already present!
[87338.910843] usb 2-2: new low-speed USB device number 58 using xhci_hcd
[87339.025875] usb 2-2: device descriptor read/64, error -71
[87339.243812] usb 2-2: device descriptor read/64, error -71
[87339.352913] debugfs: Directory '28' with parent 'devices' already present!
[87339.466841] usb 2-2: new low-speed USB device number 59 using xhci_hcd
[87339.581882] usb 2-2: device descriptor read/64, error -71
[87339.803879] usb 2-2: device descriptor read/64, error -71
[87339.912941] usb usb2-port2: attempt power cycle
[87340.224912] debugfs: Directory '29' with parent 'devices' already present!
[87340.540844] usb 2-2: new low-speed USB device number 60 using xhci_hcd
[87340.541475] usb 2-2: Device not responding to setup address.
[87340.541598] debugfs: Directory '30' with parent 'devices' already present!
[87340.745309] usb 2-2: Device not responding to setup address.
[87340.745485] debugfs: Directory '22' with parent 'devices' already present!
[87340.952785] usb 2-2: device not accepting address 60, error -71
[87341.066838] usb 2-2: new low-speed USB device number 61 using xhci_hcd
[87341.067472] usb 2-2: Device not responding to setup address.
[87341.273463] usb 2-2: Device not responding to setup address.
[87341.273584] debugfs: Directory '02' with parent 'devices' already present!
[87341.480837] usb 2-2: device not accepting address 61, error -71
[87341.480949] usb usb2-port2: unable to enumerate USB device
Output from sudo lsusb
and sudo lsusb -t
[veta@equis ~]$ sudo lsusb
Password:
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 04f2:b2ea Chicony Electronics Co., Ltd Integrated Camera [ThinkPad]
Bus 001 Device 007: ID 0a5c:21e6 Broadcom Corp. BCM20702 Bluetooth 4.0 [ThinkPad]
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 057: ID 0483:374b STMicroelectronics ST-LINK/V2.1
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[veta@equis ~]$ sudo lsusb -t
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 57, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 1: Dev 57, If 1, Class=Mass Storage, Driver=usb-storage, 12M
|__ Port 1: Dev 57, If 2, Class=Communications, Driver=cdc_acm, 12M
|__ Port 1: Dev 57, If 3, Class=CDC Data, Driver=cdc_acm, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/3p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 4: Dev 7, If 2, Class=Vendor Specific Class, Driver=btusb, 12M
|__ Port 4: Dev 7, If 0, Class=Vendor Specific Class, Driver=btusb, 12M
|__ Port 4: Dev 7, If 3, Class=Application Specific Interface, Driver=, 12M
|__ Port 4: Dev 7, If 1, Class=Vendor Specific Class, Driver=btusb, 12M
|__ Port 6: Dev 4, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 6: Dev 4, If 1, Class=Video, Driver=uvcvideo, 480M
Power is fed via the programmer ST-LINK, which is connected to same PC, different USB port.
I have split open a USB cable and soldered header pins to each of the 4 wires inside.
- White (D+) is connected to PA12
- Green (D-) is connected to PA11
- Red (VBUS) is connected to PA9
- Black (GND) is redundant as the MCU is fed from same power source, but I have tried with it connected to one of the GND pins too
I have also tried setting USB into FS mode manually by pulling up D+ USB pin with a 1.5k Ohm resistor:
and leaving pulling-up to the MCU to handle:
In STM32CubeMX my configuration is as follows, everything else is left default:
USB_OTG_FS under Connectivity tab:
- Mode: Device Only
- Activate VBUS: yes
- Avtivate SOF: no
USB_DEVICE under Middleware tab:
- Class for FS IP: Communication Device Class (Virtual Port Com)
RCC under System Core tab:
- High Speed Clock: Crystal/Ceramic Resonator
Clock Configuration is set in such a way, so that 48MHz clocks is set to 48MHz.
If something is unclear, tell me so. It's 2 am and I was working with this for last 15 hours now.
