I am builing a circuit, and i need to connect a few different IC's (obiosly). My circuit is based on 5V TTL logic and i found a part that is made only in AHC/AHCT variant.
So let's take it from the start:
  • HCT -> 5V TTL
  • HC -> CMOS technology
  • AHCT -> advanced 5V TTL ?
  • AHC -> advanced CMOS ?
I have read, that i should not mix HC with HCT together, so can i use HCT <-> AHCT and HC <-> AHC? Does it work like that? What if i want to use a CMOS chip in my TTL design?
Tanks for any help.
Kralik_011
  • 307
    There are level translators ICs you can use. I would not assume you can connect a logic family together just because you haven't seen anyone say you can't. Check the logic thresholds in the datasheets. – DKNguyen Oct 28 '19 at 21:59
    HCT is not TTL logic. It's CMOS logic with TTL-compatible inputs. The outputs will likely be CMOS rather than TTL levels. – The Photon Oct 28 '19 at 22:11
    Can you share a datasheet to the specific part you're asking about? – The Photon Oct 28 '19 at 22:12
The families differ by speed AHC is faster than HC. HCT and AHCT are TTL compatible and HC and AHC are CMOS:
Source: http://www.ti.com/lit/sg/sdyu001ab/sdyu001ab.pdf
enter image description here Source: http://www.ti.com/lit/sg/sdyu001ab/sdyu001ab.pdf
Also, a useful compatibility chart, CMOS can go 'into' TTL, but TTL cannot go into CMOS (it can't switch it on)
Voltage Spike
  • 75,799
  • 80
  • 208
  • The HCT and AHCT families are still based on CMOS transistors, but have TTL compatible inputs. – remcycles Oct 28 '19 at 22:37
    "HCT and AHCT are TTL" Nope. Read the data sheets. HCT and AHCT have TTL compatible inputs but are HC or AHC inside. – TimWescott Oct 28 '19 at 22:50
  • @Tim I'm not going to argue with TIs classification – Voltage Spike Oct 28 '19 at 23:36
    You're looking the page that says what the voltage standards are, and which technologies adhere to those standards. That's no the same thing as what's inside the chip. The section *in that same document* titled "Advanced High-Speed CMOS" is about AHC/AHCT. The "C" in 74C, 74HC, 74HCT, 74AHC, 74AHCT, etc., stands for "CMOS". So -- I'm not going to argue with TI's *classification* either. – TimWescott Oct 28 '19 at 23:44
  • "CMOS can go 'into' TTL, but TTL cannot go into CMOS (it can't switch it on)" However despite what the tables you have posted imply, "TTL compatible CMOS" *can* go into regular CMOS, because while it has TTL compatible input thresholds at has CMOS output voltages. – Peter Green Oct 29 '19 at 13:49
If they are all running on 5V, you can freely mix AC, ACT, HC and HCT.
The 'C' means CMOS, all these parts have a GND-Rail output swing.
The 'T' means TTL compatible inputs, that is 0-0.8V = lo, 2V to Rail = hi. This range means they can also be driven with a CMOS rail to rail swing as well.
The 'H' means high speed, and they are a lot faster than the 4000 series that was the previous popular CMOS family.
The 'A' means advanced, basically a few times faster than the H versions.
Neil_UK
  • 158,152
  • 173
  • 387
    There *might* be a speed impact from using the 'T' versions, and probably a noise immunity impact. Unless the OP is aggressively pushing the speed envelop, though, this is the answer. – TimWescott Oct 28 '19 at 22:51
You can mix and match logic families, but it depends on the direction of the signals and the input/output logic thresholds that each family has. You want to make sure that the \$V_{OH}\$ of an output pin is greater than the \$V_{IH}\$ threshold of the input pin, and \$V_{OL}\$ of an output pin is less than the \$V_{IL}\$ threshold of the input pin.
This page graphs the threshold voltages for a few different families: http://www.interfacebus.com/voltage_threshold.html
See page 4 of TI's Logic Guide for another graph and a compatibility chart: https://www.ti.com/lit/sg/sdyu001ab/sdyu001ab.pdf
For example, a 5V CMOS output can drive a 5V TTL input, but a 5V TTL output can't drive a 5V CMOS input.
Since that particular incompatibility is a nuisance, there are some CMOS families that have TTL compatible inputs (they can be driven by TTL outputs). These families have "T" in the name, for example: ACT, HCT, etc. You can see this in the input thresholds graphs I linked to.
remcycles
  • 429
    These are just the guaranteed maximum/minimum values. In practice, 5V CMOS and 5V TTL can work together in any combination. Just because a TTL chip has Voh of 2,4V doesn't mean it will always only drive so low. Under normal circumstances (i.e. load conditions), it will still pull the pin up to 5V. The more problematic issue is that CMOS devices can work on Vcc higher than 5V.. I've had people wonder why their stuff went up in smoke when they tried to drive a TTL input with a 12V output from a 4000 series chip. – WooShell Oct 29 '19 at 12:42
