I was studying about currents in an injected semiconductor (by illumination) from Integrated Electronics by Millman and Halkias. They consider the diffusion hole current in an injected n-type open-circuit uniformly doped semiconductor, assuming that hole concentration is negligible compared to electron concentration, and hence, the hole drift current can be neglected as it is proportional to the hole concentration.
Since the semiconductor does not have any external potential difference, drift current due to either charge carrier should be zero. But it is said that the diffusion current density of the holes causes an internal electric field leading to the drift current of electrons, and the relation \$J=\sigma E\$ is used to calculate the field (which is non-uniform) where \$E\$ is the electric field caused by the diffusion current density, \$\sigma\$ is the conductivity and \$J\$ is the diffusion current density which is not constant as it depends on distance from illumination.
The net current (which is the sum of hole diffusion current, electron diffusion current and electron drift current) is zero as it is an open circuit. How, physically, does the current density cause an internal electric field?
ocrdu
  • 8,705
  • 30
  • 42
Anubhab Das
  • 121
  • \$\sigma\$ is the conductivity and \$\mathscr{E}\$ is an *externally* imposed field expressed in volts per meter. \$J\$ is just the current density, usually assuming uniform current in the device due to the imposed field intensity and a uniform area from one end to the other (of course.) Open circuit, there cannot be any current flow (except for a very short time after being opened, as there's no closed loop for the current.) There can be gradients in the doping, for example. But I'm not sure you are discussing that situation. Can you add more to your question? – jonk Oct 14 '19 at 02:46
  • @jonk I have edited to the question. – Anubhab Das Oct 14 '19 at 05:32
That seems a really bad book on Semiconductors. It doesn't explain things clearly.
You better read one of these on that topic:
Solid state electronic devices | 7th edition -Streetman and banerjee
Semiconductor Physics and Devices (SIE) | 4th Edition - Donald Neamen
Semiconductor Devices, Physics and Technology | 3rd edition - Simon Sze and Ming-Kwei Lee
The streetman and banerjee book seems to require advanced math such as first and second order ordinary differential equations. Some algebra and calculus knowledge is a pre-requisite.
Amit M
  • 394
Before illumination, the charge density at any point is zero in the semiconductor. Once illuminated, the generated excess carriers (electron hole pair) start diffusing into the semiconductor. If both the carriers diffuses in the same manner, the semiconductor will be having zero charge density at each and every point.
But electron and hole has different diffusion coeffient, which makes the diffusion profile different and makes some part of the semiconductor to have positive charge density and some other part to have negative charge density. This creates an internal electric field from positive to negative.
nidhin
  • 8,197
