I'm working on a project with a PMSM. As I go through the literature I come across the following terms and wanted to make sure that I am getting right which ones are synonyms.
Surface-mounted PM = Non-salient pole rotor = Round Rotor = Cylindrical (in this case Inductances \$L_d\$ and \$L_q\$ are equal)
Interior Mounted PM = Buried PM = Salient pole rotor (in this case \$L_q \neq L_q\$)
Is that right?
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
cb_ann
  • 71
  • When you say 'round rotor' for the surface PM rotor, that means the steel hub, and with magnet arcs of uniform radial thickness. For surface PM rotors with breadloaf-shaped magnets, or magnets that don't cover the full circumference and have positioning nubs on the hub, the Ld and Lq values will still not be quite equal. – Phil G Oct 02 '19 at 13:38
You are correct !
Burried magnet change the permitivity distribution inside the rotor. Thus depending on the arrangement of the magnets, asymetrising its direct and quadratic inductances.
Look at this post: Explanation of Lq, Ld and how it relates to motor inductance
And this paper (if you can): https://doi.org/10.1109/emobility.2010.5668074
benguru
  • 875
