I'm just an amateur in this and I Need Help..
I've drawn this circuit of my Shaving machine and I want to remove the battery and connect it directly to one of these phone chargers-:
The first: output 5.7v ~ 800mA
or
The second-: output 5v ~ 350mA
or
-The shaving machine charger: 3v ~ 200mA
Will Any Of These Work? Shaving machine
Free Bird
  • If the motor is intended for 1.2 volt operation, neither the 5 volt or 5.7 volt power supply is suitable. If the existing battery is dead, you should replace it with a NiMH cell, rather than trying to run the thing from random external power supplies. – Peter Bennett Sep 26 '19 at 01:40
  • @PeterBennett I have tried to run the Motor directly with the charger 5v the Motor was fast and very powerful but the problem when the blade was placed on the Motor did not move at all So I think it should be to connect Resistor Or something else – Free Bird Sep 26 '19 at 01:55
  • https://www.ebay.com/itm/DC-DC-Buck-Step-down-Converter-1-25V-1-5V-1-8V-2-5V-3-3V-5V-3A-Voltage-Regulator/322586242419 – Bruce Abbott Sep 26 '19 at 02:40
  • @BruceAbbott Thanks but I think we can modulation this circuit by adding some thing or replace – Free Bird Sep 26 '19 at 02:49
    A DC/DC converter is the only 'thing' you can add that could make your supply work. Otherwise get a replacement battery. – Bruce Abbott Sep 26 '19 at 03:39
  • @BruceAbbott what if i replaced the motor with anther motor 3v ?? – Free Bird Sep 26 '19 at 03:44
  • buy a mini360 buck converter for 50c on aliexpress and use that to produce the 1.2V your motor wants. – Jasen Слава Україні Sep 26 '19 at 10:32
  • @VoltageSpike What is the function of the Diode in my circuit? – Free Bird Sep 27 '19 at 04:08
  • @FreeBird What circuit, all I see is a PCB, you need to reverse engineer the circuit – Voltage Spike Sep 27 '19 at 05:19
0 Answers0
