The component appears to be damaged, but the datasheet for the board in question shows that this is a 47k ohm variable resistor. Looks like a trimmer, but not 100% sure.
However, I've been trying to find a similar looking component with the same rating to no avail. Most SMD trimmers that I have found with a similar rating have two terminals in one side, and one terminal on the other. The board in question is a controller board attached to a LCD panel.
Datasheet: https://datasheetspdf.com/pdf-file/762847/AUO/M200RW01-V0/1
