What exactly is the difference between Tesla Coil and Tesla Tower? What does the tower do? How does it affect the propagation of electric energy?
A Tesla coil can generate voltages of high potential. I have seen videos of how this thing works but never saw a Tesla coil in combination with the tower.
What is the original purpose of Tesla tower?
"In the course of certain investigations (...) I observed that sensitive receiving instruments (...) at times failed to respond when they should have done so, and (...) I discovered it to be due to the character of the electrical waves which were produced in the earth by the lightning discharges and which had nodal regions following at definite distances the shifting source of the disturbances. From data obtained in a large number of observations of the maxima and minima of these waves I found their length to vary approximately from twenty-five to seventy kilometers, and these results and certain theoretical deductions led me to the conclusion that waves of this kind may be propagated in all directions over the globe (...). Recognizing in the existence of these waves an unmistakable evidence that the disturbances created had been conducted from their origin to the most remote portions of the globe and had been thence reflected, I conceived the idea of producing such waves in the earth by artificial means with the object of utilizing them for many useful purposes for which they are or might be found applicable." -- NIKOLA TESLA U.S. PATENT 787,412
Here's how Nikola Tesla began to think about creating lightning discharges artificially. Through observation of the results of measurements and theoretical deductions, he came to conclusion that electric waves created by lightning travel all over the globe.
What do you think about the accuracy and validity of his conslusions? What kind of instruments did he had? Do electric waves really travel throught he Earth as he described?
Dave Tweed
  • 168,369
  • 228
  • 393
Marino Klisovich
  • 265
    Have you googled this at all and, if so, please link the sites you have read and any misunderstandings you may have. – Andy aka Sep 21 '19 at 09:55
    Note to HNQ visitors: Don't feed the tesla magic energy fanboys. – pipe Sep 22 '19 at 08:46
A "Tesla tower" is simply a vertical Tesla coil with grounded base.
But to demonstrate worldwide transmission of useful power (not signals,) it must operate in the range of 100s of kilowatts, with a terminal potential of megavolts, and operating as a "cavity probe" rather than as a quarter-wave antenna tower. The high potential requires a smooth terminal of large radius (many meters,) as well as a grounding-system which tolerates tens of kiloamperes.
The physics of cavity-probes only becomes relevant when the operating frequency is matched to the cavity frequency (i.e. must hit one of the frequency-modes of the Earths ionospheric Schumann duct.) The Tesla coil provides an "transmatch" to couple to extreme high-Z of electrically short tower at VLF wavelengths, while the cavity-probe phenomenon increases the same effect. Also, the Q of Schumann resonances is very low at 100KHz, higher at 100Hz, and rf measurements/theory predicts the dividing line of roughly ~20KHz. Unfortunately, the cavity-resonance frequencies wander around on a scale of tens of seconds, so any fixed-frequency transmitter will fail, and any transmission at above 20KHz will fail.
So, in order to prove Tesla's claims, and operate even a tiny 1-watt flashlight bulb at hundreds/thousands KM distance, we'd need:
  • 17KHz operating frequency (or ideally far lower.)
  • 50MV terminal potential (or ideally far higher.)
  • Extensive grounding system (like BBC and VOA European megawatt towers.)
  • 100MW power supply (or ideally far more.)
  • method to follow the changing planetary VLF resonance modes
Got ten million dollars to blow? Then you can be one of the several investors needed for full testing Tesla's power-broadcast claims!
Or, if you only want the 2-man-staff, fifty-watt test performed up in the ham bands at 10KM range, then see this paper which debunks Norton ground-wave theory in favor of Zenneck-wave theory (the former theory proves Tesla wrong, the latter supports Tesla's claims.)
2016 Corum, Corum, & Miller, "Surface waves and the ‘crucial’ propagation experiment — The key to efficient wireless power delivery" https://ieeexplore.ieee.org/document/7577497
(Here's a non-paywall version: http://web.archive.org/web/20161019214341/www.texzontechnologies.com/wp-content/uploads/2016/09/TEXZON_Baylor_Corum16.pdf )
The Corum bros. are the ones who managed to attract $50M of funding to build the enormous Texzon/Viziv Inc. fiberglass VLF tower in Milford, Texas. It was supposedly operational late last year, see:
Viziv Inc., CEO conference talk https://www.youtube.com/watch?v=wFiW2lqdnlM&t=2m30s
Slideshow from above talk http://amasci.com/graphics/st/
Texzon tower, funded by Bahrain? https://www.youtube.com/watch?v=GZV7-keRFq8
Recent patents by JF Corum https://patents.google.com/?inventor=James+F.+Corum&sort=new
PS
Personally, I suspect that the Corums' are lacking one of Tesla's central secrets, and that the cavity-probe effect, paired with 100MV operating voltage will yet prove insufficient for broadcasting worldwide kilowatts. All the above was just one of the two techniques Tesla claimed to be using to achieve worldwide power broadcasts. The other trick, direct atmospheric conductivity at tens of KMs scale, is a lost Tesla secret, and assumed by the sci/eng communities to be impossible.
wbeaty
  • 10,761
  • 39
  • Thank you for an extensive answer. The 20kHz frequency is very close to Tesla proposed operating frequency for his coil: "(...) To give an idea, I would say that the frequency should be smaller than twenty thousand per second, though shorter waves might be practicable." (US787412A). If not for world-wide energy transfer, TCs could be used for charging large number of EVs or even for small circular towns, with houses positioned at antinodes of TC's scallar wawes. – Marino Klisovich Sep 21 '19 at 22:49
A Tesla tower what you mention is the Tesla magnifier. It is different from Tesla coil, it has an additional tank inductor.
simulate this circuit
The original purpose was to generate a standing wave in the Earth crust. With a suitable resonance receiver it should be possible to tap the energy at large distance (worldwide). The transmitter would 'sense' the load directly as classical wired generator. Tesla calculated that the loss would be typically 5% which is not bigger than traditional powerline loss.
Marko Buršič
  • 23,562
A Tesla coil is a high voltage generator. A Tesla Tower is a just big one.
Sadly, some otherwise good scientists/engineers have some really sad ideas, and this was Tesla's. There's no magic, no useful long distance transfer of power through the air, no free energy. But Tesla coils are great at generating pretty sparks.
Neil_UK
  • 158,152
  • 173
  • 387
    Has anyone demonstrated the properties of tesla tower? Are you speaking from your experience? I'm interested what a scalled-down version of original Tesla tower could do, regardless on presently held opinions. – Marino Klisovich Sep 21 '19 at 11:25
    Yes, Tesla demonstrated the properties of the Tesla Tower. The result was that it didn't revolutionise the world's electricity supply. Scaled down versions generate nice pretty sparks. – Neil_UK Sep 21 '19 at 11:29
    If you really are hot under the collar to demonstrate what Tesla Towers can do, then I'd suggest you get on with it and prove the entire electricity supply industry wrong. No-one who knows anything about electrical engineering is going to waste their time on it. – Neil_UK Sep 21 '19 at 11:32
    How do you know, that there is no useful long distance transfer? Everything he did, worked. If he hadn't funds to finish it doesn't mean that it doesn't work, As a scientist you should differentiate between 'mad' propaganda and true scientific work. – Marko Buršič Sep 21 '19 at 12:41
    @Neil_UK . Tesla was never able to demonstrate his tower, because investors wouldn't fund it, and it wasn't completed. RESEARCH FIRST, don't just criticize. Where N. Tesla is concerned, critics copy the statements of earlier critics, creating "game of telephone." Absence of evidence is just untested claims, not "disproof." Also, read engineering papers on Tesla's tower for pro and con info, not just push a one-sided viewpoint. Recent example: https://ieeexplore.ieee.org/document/7577497/ , it shows Wardenclyffe may have worked if completed. wo/metal sphere, required 100 megavolts missing. – wbeaty Sep 21 '19 at 18:45
    @Neil_UK "prove the entire electricity supply wrong." Heh. That many engineers couldn't be wrong? Sure they could, and these fallacies are always trotted out against disturbing discoveries, whenever we can't say "it failed when tested.". Also note that Tesla's system doesn't work ...if running below Megawatts, since global VLF-duct loss is ~MW range. Desktop versions work fine, engineering calcs show feasibility, but critics simply refuse to read those papers. Really, only a multi-megabucks test can settle the issue. Like this one: VIZIV slideshow http://amasci.com/graphics/st/ – wbeaty Sep 21 '19 at 18:51
    @MarinoKlisovich unfortunately a scaled-down Tesla tower is forbidden in theory and practice. Global losses are in the range of 500KW and above, so without an enormous device, Tesla's system can't even light a flashlight bulb. But the physics was analyzed in the 1980s and the system found to be feasible (earlier analyses were anti-Tesla debunkings, and full of mistakes only corrected decades later.) The recent 1980s/90s Corum engineering papers were ignored, so Corums finally performed field-testing to verify their findings, see https://ieeexplore.ieee.org/document/7577497 – wbeaty Sep 21 '19 at 19:00
  • I really feel that TCs--and high power/voltage/frequency currents in general--could be used for something very usefull. – Marino Klisovich Sep 21 '19 at 23:05
    @MarinoKlisovich Maybe. Have you seen [these guys](https://www.lod.org/)? – Neil_UK Sep 22 '19 at 05:18
  • @Neil_UK I'm suprised nobody is stopping him. The full-scale tower won't hit the ground with lightning. Well see the results. Thanks! – Marino Klisovich Sep 22 '19 at 19:15
  • @MarinoKlisovich the LOD guys ran their 40ft portable 200KW prototype at the Tesla museum at Wardenclyffe. (Portable power was apparently a trailer filled with Lithium cells!) They want funding for 3X taller. https://www.lod.org/research/research.html – wbeaty Sep 24 '19 at 00:57
