We've noticed that off-the-shelf LEDs exhibit some change in the shape (and sometimes peak) of their spectrum as the amount of current flowing through them changes.
For example, a UV LED we tested showed the following change in the shape of it's spectrum when we changed from 0.2 mA (black line) to 2 mA (orange and green line).
According to some information I've found, the magnitude of this effect may relate to the quality of the semiconductor crystal used during manufacturing.
I'm wondering if anyone knows of a supplier that produces extremely high quality LEDs that may exhibit more stable spectra. Or, perhaps there is another solution someone is aware of to improve the spectral stability of LEDs vs. current.
clabacchio
  • 13,481
  • 40
  • 80
mark
  • 181
  • Do you want UV, visible spectrum, or something else? – Chris Laplante Oct 29 '12 at 19:49
  • We would like to find stable UV and color (red, green, blue) LEDs. They all seem to exhibit this issue to varying degrees. – mark Oct 29 '12 at 19:55
  • UV LEDs vary from 340 to 400 nm. Fabrication challenges on bandgap strain and dopant exist with shorter wavelengths below 365nm. Can you elaborate on all specific requirements of wavelength, tolerance, emission levels, stability and volume demand of all types? – Tony Stewart EE75 Oct 29 '12 at 20:09
  • We're working with 395nm UV LEDs, but we need a solution for LEDs across the visible spectrum as well. It's not important that the LED have a high manufacturing tolerance (we measure the spectrum of every LED we use). The important thing is that the LED's spectrum is consistent vs. current. We would want the highest tolerance in this regard (cost is not important). We're a lab so volumes are low. – mark Oct 29 '12 at 20:15
  • Do you want a more spectrum because you think it will also give you a more robust, longer-lasting part? Or are you going to use it in a spectroscopy application? Or something else? – The Photon Oct 29 '12 at 22:11
  • ...a more stable spectrum... – The Photon Oct 29 '12 at 22:17
It might be better to talk to an apps engineer at the the company that makes your LED's. there are several mechanisms possible that will cause wavelength shifts and unfortunately the solutions are often are at odds. HEre are some scenarios and possible solutions:
1) if it's a heating effect and wavelength is shifting with atomic spacing change then PWM might be the way to go. BUt this would manifest itself as a broadening of the spectrum, you seem to be getting peaking at certain wavelengths. The activation energy of that subsidiary peak should tell the manufacturer something.
2) but the effect might be from ballistic transport of the carriers which are then causing spectral spreading collisionally - in that case a DC approach would be best as you want to avoid current spiking.
3) higher current means a larger volume involved with conduction which means a greater chance of interacting with dislocations and crystal defects and traps.
placeholder
  • 29,982
  • 63
  • 110
One such LED that immediately comes to mind is this one: https://www.sparkfun.com/products/11393. It has a well-defined spectrum (at least according to the datasheet):
You can get them on Mouser, but it looks like SparkFun has the better price (they're trying to get rid of them).
Avago is the company that makes this particular one. If you do a search on their website for Well Defined Spatial Radiation Patterns, you'll get a bunch of other LEDs similar to this one. I'm sure there plenty of other companies that produce these kinds of LEDs.
Chris Laplante
  • 2,151
  • 32
  • Interesting. That gives me something to go on, thanks. It's not clear to me that having a consistent spatial radiation pattern necessarily indicates a consistent spectrum, but it's worth a shot. – mark Oct 29 '12 at 20:09
  • @Mark: Sure, no problem! I'm not sure that that this the defining factor for these types of LEDs. It was just the key term from the datasheet that brought up similar search results on Avago's website. – Chris Laplante Oct 29 '12 at 20:11
Use PWM instead of DC. This way you always have one current level, but you are just varying the average power.
Hassan
  • We have noticed that PWM maintains a more consistent spectrum but we also require linearity of the LED's intensity vs. frequency and we haven't been able to achieve that. – mark Oct 29 '12 at 20:31
If price is not important for a small qty, why play with conventional LEDs and why not use semiconductor lasers?
I superimposed your graph with some semiconductor laser responses. enter image description here The critical difference between conventional LED and laser LEDs is the resonant properties which shape the spectral purity and emission beamwidth.
If you are planning to get into Bio-engineered products or low cost Spectroscopy exactly what are your other requirements besides lower spurious sidebands of emissions?
  • Hmmmm. I'll look into these laser diodes. The most important requirement is that the spectrum stay consistent vs. current. I wonder if we wouldn't see a peak wavelength shift with these diodes. Can you dim laser diodes as you would an LED? – mark Nov 08 '12 at 04:01
  • all leds shift spectrum with a rise in junction temperature Lasers will be more stable due to high Q resonance. – Tony Stewart EE75 Nov 08 '12 at 06:22
