I have a SOC that has a KSZ9031RN PHY, that is a Gigabit PHY. But I'm going to use only in 10/100 Mode with 4 wires.
Gigabit PHY datasheet recommends a magnetic for Gigabit Ethernet, that are different from Fast Ethernet magnetics.
Can I use 4 Wire Fast Ethernet magnetic with that Gigabit PHY if I'm going to use it only in 10/100 Mode?
Thanks!
Indexer
  • 51
Short answer: Yes you can use the KSZ9031RN with only 10/100 magnetics.
Read the Support datasheet and note section 3.8.
So you will have to program the devices to ensure it does not attempt to size 4-pair as opposed to 2-pair connections.
Jack Creasey
  • 21,428
