I want to put a point here:
'It's not the Voltage but Current that kills someone "
The current rating of your power supply is not what it will always deliver. This rating simply indicates that this is the upper limit of current which this power supply is capable of delievering. Rated Voltage is something which is constant across the output. What flows through your body is the current which is actually delivered from the supply (according to ohm's law) and not the rated one. Have a quick look at the ohm's law.
I=V/R
At 12V and typical body resistance, say, 100k ohm, the current turns out to be 0.12mA(not 6.5A). This is way too less to harm our body. Even if you measure the resistance between two points inside your mouth, say tongue, it turns out to be more than 10k ohm's, which still permits only 1.2 mA current(though it may feel like a small sweet shock but safe! )
Though it is the voltage that is the cause of current, but what actually kills you is the CURRENT.
Because your supply is able to deliver more current; in case of short circuit it will cause more heat dissipation and hence more damage before it is cut off due to some reasons. This is where you have to be careful.
