When a MOSFET is working in its saturation region, it might be used as an amplifier. But, as far as I understand, the more you increase vGS
(voltage between the MOSFET's gate and ground) the less output voltage you get, which is the opposite of amplifying. Let me explain:
Having this (supposed) amplifier:
when it is in saturation region, it behaves as a VCCS, which, apparently, leads to an amplifiers' behaviour:
In the above picture, vO
will be VS - eL
, if eL
is the voltage drop in RL
. Following the iD
equation, the more vIN incrases, the more voltage drop you will have in RL
, right? That means that the more vIN
increases, the more vO
decreases. That isn't amplifying, but the opposite.
What am I missing?
