I know that .data
will be in the RAM, but I came across article that says during boot of an micro-controller the initial value of variables is stored in the ROM and then the boot-loader copy the initial values of variables from ROM to RAM, Is this true!?
Asked
Active
Viewed 136 times
Abd El-Rahman Akram
- 25
- 3
Related: [What resides in the different memory types of a microcontroller?](https://electronics.stackexchange.com/questions/237740/what-resides-in-the-different-memory-types-of-a-microcontroller) – Lundin Aug 21 '19 at 06:26
Ask yourself how could the system work if it isn't true?
In most implementations, the .data
segment is for initialized data, where .bss
is for data that is set to zero. You can't count on RAM being set to anything at all on power-up, so the processor has to zero out the .bss
segment and initialize .data
Usually this is done by storing an image of the start-up value of the .data
segment in ROM, and copying it to the correct location in RAM on startup.
TimWescott
- 44,867
- 1
- 41
- 104
the bootloader of laptops and computer also does the same thing!? – Abd El-Rahman Akram Aug 19 '19 at 20:19
1It is not the bootloader but the startup code of *every program* stored in ROM regardless of platform. – Eugene Sh. Aug 19 '19 at 20:32
1PC bootloaders are a considerably different animal. The *BIOS* probably does it (most modern-day BIOS's are probably written in C), but the *bootload* process is multi-step, and the actual operating system comes from disk. I suggest searching on some variation of "how does the PC bootload process work" if you want to study up on that one. – TimWescott Aug 19 '19 at 20:33
A modern BIOS is a bunch of *tens* of firmwares running on different components and loaded from some kind of ROMs at different stages. And yes most (if not all) of these are working this way. – Eugene Sh. Aug 19 '19 at 20:37
@EugeneSh. so what does bootloader do in general !?, and doesn't startup code and bootloader is the same thing !? – Abd El-Rahman Akram Aug 19 '19 at 20:45
5No. A bootloader is a separate *program* which is running before the others and is intended to allow other programs to run. A startup code is a *part* of the same program, which is running *before* `main` (in C) and responsible for setting up the memory, stack and the data ad bss sections as explained for *this specific program*. Then it is calling `main`. – Eugene Sh. Aug 19 '19 at 20:48
Yes. That's how values of variables get initialized, and the rest of the variables are in .bss section which is normally cleared to zero on startup.
Justme
- 127,425
- 3
- 97
- 261
Yes if it is a program written in C language for example, C startup code initializes variables for you before main. If it is a program written in assembly, there is no startup code to do anything. – Justme Aug 19 '19 at 21:14
why in assembly there is no startup code?! How this operation works in assembly – Abd El-Rahman Akram Aug 19 '19 at 21:56
2Nobody forces you to do anything in assembly, you can write your startup if you like, or link the assembly with C startup. Feel free to look at how STM32 startup works for example. But this is now off topic for Electrical Engineering – Justme Aug 20 '19 at 04:08
