I am trying to implement a non-linear inductor in LTSpice and to get it to saturate.
I am using the following directive between N1 and N2 as advised in the help files:
L1 N1 N2 Hc=12 Br=0.2 Bs=0.4 A=4u Lm=0.4 Lg=0.01u N=100
With a DC voltage supplied the circuit behaves as if it is purely resistive regardless of the voltage.
This is the circuit I am using.
Plot. enter image description here
Is there something else that needs to be added here??
Thanks.
MXG123
  • 313
Don't make the source a DC source.
With the DC source, LTSpice is assuming the voltage has been 10 V since \$t=-\infty\$ and all transients have settled before the simulation starts.
Make it a transient source that turns from 0 V to 10 V a few ms after the simulation starts.
The Photon
  • 126,425
  • 159
  • 304
  • Yea the delay works better. Also I had too low a resistance and it was saturating almost immediately. I increased the resistor so the current was stable and then increased when it went into saturation. Thanks. – MXG123 Aug 16 '19 at 19:03
Use a PWL or PULSE source. In addition to what ThePhoton said, you can change the graph to an x-y source by clicking on the time axis and changing the time axis to a signal.
Voltage Spike
  • 75,799
  • 80
  • 208
