15
Why can't you buy a 912-digit multimeter?
Isn't there any need for it? Is a 812-digit multimeter the latest high end you can buy? I have tried Keysight, Keithley, and Fluke, but there is nothing higher than 812 digits.
Voltage Spike
  • 75,799
  • 80
  • 208
voltage_drop
  • 167
    What is your goal? – Chris Stratton Jul 27 '19 at 22:04
  • 39
    You'd need a 10.5 digit meter to calibrate it. – Transistor Jul 27 '19 at 22:09
    What's the true accuracy of even that 8.5 digit DMM? Probably not 1 part in 100 million... –  Jul 27 '19 at 23:03
    And if you found one, you'd have to have it calibrated frequently. Good luck with that. – JACK Jul 27 '19 at 23:54
    Check NIST. I think you'll find that accuracy of their best Josephson Junction devices is on the order of a some parts in \$10^{10}\$. So, roughly speaking, about 9.5 digits. And that's under optimal conditions. The equipment used to provide such a standard costs about $300k each and will probably require a PhD to operate well. There's a recent 2018 paper on the topic, "Impact of the latest generation of Josephson voltage standards in ac and dc electric metrology" by Rüfenacht, et al. DOI: 10.1088/1681-7575/aad41a. You *can* buy a voltage standard that is 9.5 digits. Not a multimeter, though. – jonk Jul 28 '19 at 00:46
    Every potential customer must answer for themselves the following questions: What are you trying to measure? Why do you require or want an accuracy of around a part in 1000 million? How would you calibrate it? What is your budget? – Russell McMahon Jul 28 '19 at 02:54
    A 10 bit ADC is only 3 digits and a 30 bit ADC is needed for 9 Digits. What planet do you live on? – Tony Stewart EE75 Jul 28 '19 at 05:16
  • It's really one or two ranges on VDC that hit the banner line digit spec, all other measurements are off a order of magnitude or two (Resistance, Current, etc) – sstobbe Jul 28 '19 at 16:15
    A typical 8.5 digit DMM will hold DC accuracy for a year of +/- a few ppm, so fewer than 6 digits of accuracy. Other ranges like AC will be much worse. Getting better than ~1ppm DC stability for any length of time or over any reasonable temperature range is **difficult** and **expensive**. – Spehro Pefhany Jul 28 '19 at 16:52
    If you can afford to set up a measuring environment where a 9+ digit meter would be useable, you can probably afford to make you own meter. Just think of the havoc trace amounts of radioactive elements would cause to the measurements, and cosmic rays could be annoying too. – Andrew Morton Jul 28 '19 at 17:35
    If you want to measure down to the nV level get this : https://download.tek.com/document/LowLevelHandbook_7Ed.pdf – Voltage Spike Jul 29 '19 at 03:48
    The moment you need a meter with such a high accuracy, it's usually specialized meters you'll find and not multimeters. 8.5 is plenty for most uses and it's simply too expensive to go higher. If you got that kind of money, you're no longer interested in multimeters but have a rack full of specialized equipment. – Mast Jul 29 '19 at 05:46
    I wonder how you'd connect such a meter to a circuit that you wanted to measure. – MaxW Jul 29 '19 at 06:00
    Because 8.5 digit meters are already lying liars, and they got embarrassed at lying more. Related: https://xkcd.com/2170/ – Yakk Jul 29 '19 at 20:42
    Do you need those measurements in terms of the latest SI standard that sets exact numerical values for Planck's constant (h) and the elementary electric charge (e), or the older definition with the kilogram defined as the mass of a specific platinum-iridium cylinder in Paris? Because at that level of precision, it makes a difference. – dan04 Jul 29 '19 at 22:08
    Measuring ANYTHING to 9 significant figures is extremely difficult. Imagine measuring a steel bar that is 1 meter long, and you have to measure it to the nearest micron. That is only 6 significant figures. How would you measure it to the nearest nanometer? – user57037 Jul 30 '19 at 01:37
Four reasons:
  • Because modern meters have an autoranging function.
  • Because the dynamic range of the analog system would not support 912 digits, with a range of 1 V the noise floor would be in the nanovolts (you can't get lower than nanovolts because of thermal noise, without significant cooling of what your measuring, the cables and the meter to reduce the thermal noise temperature), and all of the digits below the 9th would be noisy.
  • ADCs usually have a 5 V range, and even with a 24-bit ADC, you'll have roughly 60 nV per bit which restricts the resolution of the last digits.
  • On a 6.5 digit meters that are commonly used, for most measurements around a normal lab have noise in the uV range. And the last digits are commonly noisy on a 6.5 digit meter. One more digit might be nice for some applications, 3 more digits would be frivolous.
Even nanovolt meters don't have 912 digits.
For most measurements 6 (or so) digits will suffice because great care must be taken to lower the noise floor below 1 μV.
Here is a cool scale that also illustrates the point:
Source: Understanding and Applying Voltage References
It's difficult to obtain gains larger than 140dB with an analog subsystem, and about that point your also limited on resolution. Gaining doesn't help because of the noise inherent in all analog electronics, you gain up the signal, you also gain up the noise.
The marketing departments can ask for more digits, but it's not going to help engineers.
Voltage Spike
  • 75,799
  • 80
  • 208
    Autoranging with relays can play havoc with sensitive experiments, so in the physics lab I work in we normally turn it off. Thus for one experiment we need a 6.5 digit multimeter to get 3.5 digits at the start and not saturate the photodiode at the end. – Chris H Jul 28 '19 at 18:20
  • You can take your signal, filter it, then amplify it with a gain of 2 or more, and measure three digits there (then divide by your gain for your measurement). This is usually what is done when you need more precision with a 10-bits ADC (like the one you find on most microcontrollers) for pretty much a couple of cents in parts. – Drunken Code Monkey Jul 30 '19 at 02:58
    @DrunkenCodeMonkey Yes, this works for 10-bits, 10bits is equivalent to 3.5digits. There is no way to increase the SNR for the frequency's you are measuring. Filtering will reduce the overall pk-pk noise, but will do nothing for sensor noise. If the noise per given frequency is 10nv/Hz at the input then there is no amount of gaining or filtering to get better SNR. The other problem is every time you add a filter or analog stage, you *increase the noise*. – Voltage Spike Jul 30 '19 at 03:05
    Seeing the dB scale there really makes it sink in just how precise an instrument an 8½ digit multimeter is... – Hearth Dec 20 '22 at 03:18
15
Putting aside the signal-processing challenges, let’s examine some noise floors.
A 62 ohm resistor produces 1 nanovolt/rtHz RMS noise at 290 Kelvin, and ignoring various crystal-flaw contributors, some of which are current-level dependent and may boost that nanovolt by orders of magnitude.
So we have a 1 nanovolt random noise floor, in a 1 volt input full scale range. If you constrain the effective-noise-bandwidth to 1 cycle-per-second.
This gives us 9 decimal digits, or 30 bits (or with sign, 31 bits).
How much input signal power must we have?
Using Vnoise_cap = sqrt(K * T / C) for a switched-capacitor filter, we learn a 10 pF capacitor at 290 degrees Kelvin will produce 20 microvolts RMS random noise. This noise comes from the SWITCH (e.g. a FET, as the FET turned off).
We need to reduce the noise floor by a factor of 20,000.
This requires a capacitor of size 10 pF * 20,000 * 20,000 = 4,000 * 1,000 * 1,000 pF.
Or 4 millifarads.
What sensor energy does this require?
Power = frequency * capacitance * voltage^2
Sensor power = 1 * 0.004 farad * 1 volt^2
Sensor power = 0.004 watts
What sensors produce 4 milliwatts? A moving-coil phono-cartridge with 10 ohms (resistance of the coil) may produce 200 microVoltsRMS output; using Power = Vrms^2/Resistance, we find Power = 4e-8/10 = 4e-9 = 4 nanoWatts; thus we should not expect 30 bit music from vinyl records, even for severely filtered tones.
Now, for fun, guess what is the effective-noise bandwidth of 62 ohms and 0.004 Farads? The -3dB corner is about 4 radians per second. Integrating from DC to infinity, you get 6.28 radians per second.
Ain't nature fun?
analogsystemsrf
  • 33,703
Aside from the matter of need and accuracy from what I understand, there are two other issues: Leakage and noise.
If you go to high voltages (e.g., measuring 100 volts to 9.5 digits) you run into leakage issues: the voltage causes tiny currents to flow between lots of different points (e.g., between the positive and negative terminal cables in a coaxial cable, inside the switches of the meter, etc), which makes your last digit not that useful compared to an 8.5 digit meter already out there.
But when you go to lower voltages, say 1 volt, you run into noise and thermal offset issues. The last digit on 1 volt would be 1 nanovolt. Given the input impedance you would want (as even the smallest loading will have effect at 9.5 digits), you need incredibly long measurement times to get rid of thermal noise. At that point, 1/f noise really comes into the picture and makes everything even worse. And as if it wasn't even enough: thermal voltages (voltage generated between two metals when there is a temperature gradient across them) can be on the order of microvolts!
So all of these things require incredible control to get around, beyond what is realistically possible in a lab (In fact, to get the true performance out of a 6.5 digit meter at the lower ranges you already need to take things like thermal EMF and leakage into account), unless you are doing extreme calibration. And in those cases, the absolute reference labs will usually use custom Josephson-junction based references, where cryogenic temperatures and quantum-physics are used to turn a measurement of time (frequency, really) into a measurement of voltage. These can cost many hunderds of thousands of dollars and require a lot of expertise to operate.
user
  • 222
Joren Vaes
  • 12,376
  • 64
In a previous project I worked on, we built, tested and used precision voltage sources for Penning trap experiments. We needed \$100\,\text{V}\$ sources to be stable (i.e. precise, not accurate) in the sub-\$\mu\text{V}\$ range.
One problem with 8.5 digit multimeters and measurements at that level is that you have to deal with thermal potentials and contact potentials, which severely degrade your accuracy. Also, both effects are usually temperature dependent, which degrades your precision, unless you have good thermal stability of the test setup. If you had a 9.5 digit multimeter, you would have to have even better control over the measurement environment.
If you really, really need a 9.5 digit multimeter, current ADC technology is not sufficient. I suppose you could set up cryogenic Penning trap for that purpose. It would have to be custom-built, cost a few hundred thousand dollars and one to two PhD students. But it can be done! Calibration would be the most tricky part, but can be done against a Josephson junction array (primary standard).
Martin J.H.
  • 651
Probably, there is a need for it, but not a big need. Not many people need that much accuracy, only some high end companies who probably make machines having also that much accuracy (for the parts that need to be measured with a 9.5 digit DMM). However, I can imagine there is a 'need' for it, or at least a wish.
The reason why there are none, is that it is probably very expensive to make one with that accuracy; if it is possible at all, it is too costly and nobody will buy it.
An analogy is a well known wafer stepper company which makes machines on nm accuracy. These machines are heavily depending on the quality of optical lenses. There are very few companies on this world who can make good lenses, and this wafer stepper company would like to have better lenses, but just at the cost that they can earn it back from customers.
Michel Keijzers
  • 13,867
  • 69
  • 139
  • Wafer stepper overlay accuracy must be below nanometers by now, no? Whether it's 10's or 100's of picometers, though, I'm not sure. – The Photon Jul 28 '19 at 00:10
  • @ThePhoton True indeed, overlay (which is the smallest accuracy for placing layers is in 0.5 nm now afaik, maybe even smaller), however internally for some steps picometers might be used. – Michel Keijzers Jul 28 '19 at 00:20
  • Also, if you have to measure or encode such precise values in an analog fashion, you'll try very hard to take them to the time instead of voltage domain ASAP. – rackandboneman Jul 29 '19 at 03:11
  • I don't see how this comparison is relevant. Mechanical positioning can be measured optically, and all you need is a **relative** offsets to be less than 0.1 nm when performing triple patterning. But you really don't care where exactly on that big 300 mm silicon wafer you end up. – MSalters Jul 29 '19 at 10:05
  • @MSalters It's not about (distance) measurements, it's about the lenses that need to be so accurate to be able to direct a beam over meters of distance onto a nanometer level reticle/wafer. – Michel Keijzers Jul 29 '19 at 10:55
  • @MichelKeijzers: It wouldn't matter if the beam was shifted to the left by a thousand nanometers. Every part of every chip would move by the same distance. – MSalters Jul 29 '19 at 11:00
    @MSalters Not of the new layer needs to be on top of the existing layer. – Michel Keijzers Jul 29 '19 at 11:20
