I am doing project in which I want to perform read and write operation by using a capacitive touchscreen. What I know is I can trigger capacitive touch screen by:
  1. By using electromagnet as I heard that some of stylus works by using magnet at its point so I think electromagnet should work.
  2. By using capacitor: If I connect a capacitor's one end to vcc and other to a conductor plate then I think it will mimic the property of human finger and trigger touchscreen.
I want to use these system so I not need to make any physical changes. If I want screen to trigger then I can just charge capacitor or electromagnet. I want to know that whether my theory is correct or not and if there is any suggestion for that then let me know.
Passerby
  • 72,580
  • 90
  • 202
Capacitive touch screens work by altering the AC electric field on a fine grid in the phone screen that's detected as a change in capacitance at that node.
You should be able to alter the capacitance by touching the screen with a grounded electrical conductor. A quick trial with my phone shows this works.
Confirmed on EEVblog by this post."I work with capacitive touchscreens daily. When we need to control when a finger is applied to the screen, we use copper tape. The tape has a conductive adhesive that keeps it on the screen. Then, a short wire to a NO relay. When the relay is activated, it connects the copper tape to ground. This increases the response to the sensor and usually appears as a finger. I've also been looking at using a series capacitor to isolate the connecting wire from the proxy finger. "
akellyirl
  • 4,117
  • 30
