I need to know how to roughly get idea about indcutance value of ceiling pedestal single phase AC fan? I want to roughly model this.
Asked
Active
Viewed 942 times
The overall inductance value of an induction motor –as typically used in ceiling fans– heavily depends on the slip.
At near synchronous speed (slip → 0), it's dominated by the field winding and for a 230V ceiling fan motor, roughly in the range of 300mH.
At standstill (slip → 1) it's dominated by the air gap and rotor magnetization which leads to an inductance of roughly 30mH.
Janka
- 13,636
- 1
- 19
- 33
If I could upvote this twice, I would. “It depends”, “Why”, “read the datasheet” and “ask the manufacturer” are the usual but way less helpful answers here. When I was in university a fellow student of mine called a transformer manufacturer to get a good approximation of the nominal efficiency of a 1 MVA transformer. “It depends on what you design for” didn’t help him. – winny Jul 21 '19 at 13:24
@Janka ,thankyou very much for your valuable feedback...can i know resistance value of fan motor as well? – Muhammad Jul 21 '19 at 13:49
The equivalent resistance depends on the torque and thus power the motor has to overcome due to the mounted fan. So P=U²/R → R=U²/P. – Janka Jul 21 '19 at 21:16
It's the R part of Z. And no, you cannot measure it with an ohmmeter. That one gives you the resistance of the wiring. – Janka Jul 22 '19 at 02:20
@Janka,For case of pedestal fan/ceiling fan rated 230/240vac, 80 watts..then R=V2/P ,it will be Z? OR R? Secondly if i measure with ohmeter,then it will be correct R value of fan motor? – Muhammad Jul 22 '19 at 02:31
@Janka, I need t refernece somewhre in my report about vaule of indcutance quoted above..Can you share source or link etc that i can reference in my reportplease? – Muhammad Jul 22 '19 at 02:32
It was *rough values*, so I cited my own memory. Sorry. – Janka Jul 22 '19 at 02:53
Thankyou very much sir@Janka – Muhammad Jul 22 '19 at 03:06
