I would like to create a SPICE model for a constant power load. I'm guessing that would involve using an equation to dynamically adjust the model's resistance based on the applied voltage. How do you do this in SPICE?
(I'm currently using Eagle but any SPICE2 or SPICE3 answer will work)
Jeremiah Rose
  • 399
Use an Arbitrary behavioural voltage source (bv). Set Value to P=10 for 10W.
If your system is starting at zero volts then follow the instructions on LTspice: Modeling Constant Power Loads and define an initial behaviour using their example. I.e create a spice directive .step param foldback list 1 3 in you schematics and set the second value line of the arbitrary voltage source to Vprxover=foldback-
cagru
  • 41
You could use a resistor and define the resistance as a function of the voltage across it. R=V_R^2/power
V_R is the voltage across the resistor (power supply) and for "power" you can use a value for the desired constant power.
I found a link to an example.
edit:
Here is the netlist:
R1 V_R 0 R=limit(0.0001,V(V_R)**2/100,10000)
V1 V_R 0 SINE(11 10 1k)
.tran 0 10ms 0s 100ns
.backanno
.end
for this simulation: enter image description here The limits are the min and max value of the resistor and can be changed to any number. But without the limit, the current will rise to very extreme values at nearly or exact 0V across the resistor (R=0). With V_R >> 0V you don't need the limits. In this case the load is 100W. You have to change the number "100" in the formula for R1.
Momchilo
  • 194
