Two part question here:
  1. Are there ways to directly test the input and output capacitance of a MOSFET, Ciss and Coss?
  2. Due to internal inductance and capacitance, is it possible for a standalone MOSFET to resonate at certain frequencies?
JRE
  • 67,678
  • 179
Jaywalk
  • 539
YES,YES 1) See best datasheets for test methods.
2) All traces have ESL starting at ~0.5nH/mm and scope probes are also notorious for ground ESL resonance with 10:1 coax xx pF, for resonance <50 MHz, thus tip/ring method is best between to nearby pins <1cm apart with gnd clip and probe tip both removed.
Depending on the FET fabrication method, you may find Rgate and Rsubstrate are adequate to dampen the resonances.
analogsystemsrf
  • 33,703
