The WM8804 looks like the ideal candidate for a design I'm working on --- this single chip could replace the need for one receiver and one transmitter. The specific routing requirements are:
I need one of the following two configurations, selectable "on-the-fly", during operation (say, a switch that a microcontroller reads, and the microcontroller uses GPIO pins to control and reconfigure the WM8804):
- I2S input → route to SPDIF output
- SPDIF input → route to both I2S output and SPDIF output
Table 15 on page 20 and Figure 15 on page 20 of the WM8804 datasheet suggest that it can do that: TXSRC selects the source for the SPDIF transmitter; the diagram in Figure 15 shows that the output of SPDIF RX goes to both the I2S and the SPDIF transmitter; if I set, in hardware/standalone mode, CSB = 0 (corresponding to TXSRC = SPDIF RX), the multiplexer will select SPDIF RX as the source for SPDIF TX, but SPDIF RX will also go to the I2S decoder and ultimately DOUT.
I have had enough ugly surprises with datasheets' misinformation (or hidden information, especially about limitations of the device) that I'm paranoid enough and would like to ask:
Anyone out there has tried this or similar configurations with the WM8804 and can confirm that this is the case?
In case this makes a difference: please notice, although I'll have a microcontroller on the same board, I really, really prefer to use the WM8804 in standalone/hardware mode; even if the microcontroller will drive the few pins that the WM8804 will read at startup to determine its configuration.
