I have read about spacing at HV design and it seems to say that there are two main standards to be followed: IPC or UL (IEC). IPC is a generic and commonly used. But UL is the best option for designs that will be used internationally. But I have also read in other post that UL 840 could be applied.
There are some clearance and creepage calculators based on UL (60950-2n edition) or IPC which are useful when you have not access to these standards. This is my case at this moment. So I tried to use the calculators.
My board will have 6KV of working voltage: some points with 6KV, other one will be 0V or 12V when system will be ON.
But trying to use them something is wrong:
  1. for creepage calculation. It only works until 1000V IEC/UL based calculator1. I can' t input 6000V there, it gives me an error.
  2. for creepage and spacing calculation IEC/UL based calculator2. When I change parameters (pollution, material, etc) it gives the same creepage distance value for all the cases. I 'm not sure it could be a good thing.
When I use creepage calculator 1 for 1000V it gives me different values comparing with the calculator 2 using the same parameters. So online calculators do not give me any confidence.
Here I have 2 questions:
  1. On the one hand I would like to know which standard tables must I follow for creepage?
  2. On the other one I'm asking for confidence calculators that can I use, especially for creepage.
Extra information about my case:
At this early point I don't really know pollution neither insulation degrees (functional, basic, etc..). Wire insulation and resistivity test, is our field. The market target could be any location of the world. This is the first time we will develop equipment with this voltage level. So, I thought to design keeping the worst case in mind. The kind of board I will design is wired relay based (its HV connectors has wires), coil relay controled by 12V signals. Not much more on the PCB. Well, it also has some wire-PCB connectors. Manufacturer offered to me CTI1 or CTI3 material. I'm considering to put HV connections/traces on the top and low voltage connectors and traces on the Bottom. I would like to add GND and VCC planes.
I keep in mind to use conformal coating after placing components. I'm waiting for the answer of the manufacturer for working with kapton instead of solder mask. After literature and researching I have learnt these 2 tips for isolation reinforcement.
Suvi_Eu
    If you want to meet the standard I would suggest buying that standard. Failing that some Libraries (esp University ones) have the standards to read for free. I have access to all UL, IEC and CE stanards and can probably answer your question for one specific case. What is your polution degree? What is your equipment class? – Jay M Jun 19 '19 at 09:47
    IPC is not a recognised safety standard, it is a design guide. You will need to apply one or all of IEC, UL or CE (dependent on your target market) if you want to make your product pass any approval testing. – Jay M Jun 19 '19 at 09:49
    These standards separate working voltage from surge voltage. The latter being a very brielf excursion with a defined shape rather than a sustained voltage. A sustained 6kV will require potting or coating or you will have some very large gaps to meet. – Jay M Jun 19 '19 at 09:52
  • [Try this](http://www.creepage.com/) – Andy aka Jun 19 '19 at 10:02
  • @JasonMorgan Thanks, at this early point I don't really know pollution neither insulation degrees (functional, basic, etc..). Wire insulation and resistivity test is our field. The market target could be any location of the world. This is the first time we will develop equipment with this voltage level. So, I thought to design keeping the worst case in mind. The kind of board I will design is wired relay based (HV connectors has wires), coil relay controled by 12V signals. Not much more on the PCB. Manufacturer offered to me CT1 or CT3 material. – Suvi_Eu Jun 19 '19 at 10:04
  • @Andyaka this is the same I was using. This calculator doesn't give me confidence as I said. It seems not to work very well. When I change pollution degree or CTI material degree the resulting values are the same. I don't feel confidence with it. – Suvi_Eu Jun 19 '19 at 10:07
  • Oh sorry, I only opened the first one. When I changed pollution degree the numbers did change. – Andy aka Jun 19 '19 at 10:09
  • @JasonMorgan yes, I keep in mind to use conformal coating after placing components. I'm waiting for the answer of the manufacturer for working with kapton instead of solder mask. After literature and researching I have learnt these tips for spacing reduction. Are two both good options, isn't it? – Suvi_Eu Jun 19 '19 at 10:11
  • @JasonMorgan sould you be kind to show the table or simply the value for clearance and creepage between 2 conductor points (traces or pads), A and B, with VBA = 6KV (for pcbs) at the worst case? The worst pollution degree case, the worst CTI degree (I think 3), etc.. if it was useful I tell you that we will use kapton mask and conformal coating spray. – Suvi_Eu Jun 19 '19 at 15:45
  • According to UL60950 in example. – Suvi_Eu Jun 19 '19 at 15:54
From UL840 (Jan 6 2005): **
6300Vdc/ACrms, Polution Degree IV, Material Group III (CTI 175 to 400) = 320mm
PD IV is a conductive or wet dust.
If you can go to Polution Degreee II (limited condensation and non-condutive dust) by controlling the evironment some way, then that reduces to 63mm.
If you can use a material with a higher CTI as well, then that further reduces to as low as 32mm.
From IEC60664-1 (1992): **
6300Vdc/ACrms, Polution degree III, Material group III, 100mm
6300Vdc/ACrms, Polution degree II, Material group I, 32mm
From IEC60664-3 (1997): ##
Up to 8kV DC/ACpeak = 3mm of solid insulation
This could also be an inner layer of a PCB or solid potting compound.
Notes:
** This is in air. The 6kV falls of the bottom of most of the tables for any coatings.
** This is at <1000m above MSL. e.g. At 7000m the dimensions double.
## Deals with coating and potting (and by inference assumes polution degree I)
Jay M
  • 3,753
  • 30
