I have been using the RC522 module to read and write things to the tags it came with. But when I tried to use an NTAG213 I bought for a recent project it will act as if it isn't there. I've tried a lot of different code to try to get it to recognize it but I haven't had any success.
I’ve mostly been trying to use the module that the RC522 needs on the arduino UNO
Have I just not been using the right code? Or is it not possible for the RC522 to recognize the tag?
Ok I was just able to scan the tag using a friend’s phone and I have found the manufacturer and the protocol. The manufacturer is NXP and it uses the ISO/IEC 14443-3 protocol '''c++
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
void setup() {
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
mfrc522.PCD_DumpVersionToSerial(); // Show details of PCD - MFRC522 Card Reader details
Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
void loop() {
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
// Dump debug info about the card; PICC_HaltA() is automatically called
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
